1985 22r motor stalling while braking
Old Jul 18, 2010 | 08:30 PM
Rockhopr's Avatar
Exclamation 1985 22r motor stalling while braking
I have a 1985 22r motor in my 82 yoda pick up that keeps stalling when I break hard, if I ease into and I mean really ease into a stop I'm ok. Now it doesn't do it when it's cold only after it heats up. I changed out the fuel pump thinking I was lacking pressure or there was a pin hole in the diaphram but it didnt fix it but helped, and I turned up the idle speed just slightly as well. It starts and idles fine (idles a lil fast now about 1200). The only other thing I can think of is that it's a vacuum issue but I really have no idea. Any help would be great! Thankx!
Old Jul 18, 2010 | 09:28 PM
myyota's Avatar
Disconnect the vacuum line going to the brake booster and plug the hose and see if it still does it. You might have a bad brake booster.
Old Jul 18, 2010 | 10:20 PM
85gijunk4x4's Avatar
my 85 22re did the same thing, turned out to be the fuel filter, but yours seems to be something else
Old Jul 21, 2010 | 06:20 PM
Granth's Avatar
mine does the same, i've come to the conclusion that it's the booster. all problems point that way.
is your pedal soft?
Old Jul 22, 2010 | 02:31 PM
rsidner's Avatar
I agree with MyYota.
Definitely sounds like a brake booster issue. Try to repeat it while standing still by just mashing on the brake pedal. If it repeats, I agree to disconnect the brake booster and plug the vacuum line.
The reason I say try it standing still is I imagine it would be a little safer and it will help eliminate any potentially stranger issues.
Old Jul 23, 2010 | 12:39 PM
Granth's Avatar
If it does do it with it plugged, is that an answer to the brake booster being bad, or something else?
Old Jul 23, 2010 | 01:25 PM
myyota's Avatar
If it still does it with the booster line plugged, then the problem is some were else.
Old Jul 23, 2010 | 06:14 PM
swampfox's Avatar
does it act up if you hit a bump or if you bounce the front end?
Old Jul 24, 2010 | 11:54 AM
Rockhopr's Avatar
Sorry it took so long long to get back first day off in awhile. So I pluged the brakr booster vacuum line and it still did it, and no there's no change when I hit a bump or anything. And I can't seem to repeat it while it's standing still
Old Jul 24, 2010 | 11:56 AM
xxxtreme22r's Avatar
by 22r do you mean carbed? sorry got to ask.
Old Jul 24, 2010 | 11:59 AM
Rockhopr's Avatar
Yes it is carbed. And it also seems to be getting worse
Old Jul 24, 2010 | 12:49 PM
84toyota4x4extcab's Avatar
is it a 5 speed?
Old Jul 24, 2010 | 01:01 PM
Rockhopr's Avatar
Yes, 4wd as well
Old Jul 25, 2010 | 06:03 PM
natureboy's Avatar
Same problem
I am having the same exact problem with my 84 4x4 22r weber 32/36. Its the exact same. anyone who can help?
Old Jul 26, 2010 | 04:17 AM
ok cus If I remember right there is something on the EIF trucks that is related to fuel supply and braking but not on the carbed trucks.
are you 100% sure its only braking or when your off the throttle (which is usually when you apply the brakes.) I hope you can follow me here.
Old Jul 26, 2010 | 04:22 AM
I have an idea what this might be need both of you to try something though.
make one hard braking each when rolling when off the throttle going slow don't use gas pedal alot. and then again after full throttle for maybe 10 seconds.
I have a feeling this has something to do with your float levels in the carb. and the amount you have for fuel pressure going to the carb.
Are you using the OEM type mechanical fuel pump with or without a regulator? do you have the fuel return line disconnected and blocked off?
Old Jul 26, 2010 | 07:30 AM
swampfox's Avatar
does it still stall after you turned the idle up to 1200 or only at the normal idle setting ?
Old Jul 26, 2010 | 07:36 AM
Tofer's Avatar
Sponsor
are you putting the clutch in?
Old Jul 26, 2010 | 07:43 AM
hahaha
Old Jul 26, 2010 | 07:44 AM
Tofer's Avatar
Sponsor
the way the questions and threads around here have been going lately i cant assume anything... not putting the clutch in when breaking would cause the motor to stall....
