1985 22 RE...water in engine...help!
Old Jul 18, 2021 | 08:46 AM
David Mclinn's Avatar
I removed my valve cover gasket today to replace the gasket, and noted water mixed in the oil. I used a head sealer years ago which worked for a long time. But maybe it's leaking again. Questions: Will the vehicle run this way so I can take it to a mechanic without making things worse? Can I use the sealer again and expect that it will/might work? What is the next step, do a compression check to confirm the head leak? David
David Mclinn
Jul 26, 2021 06:19 AM
Actonranch
Mar 13, 2013 06:41 AM
snobdds
Jun 20, 2009 09:16 PM
Quattro15
Aug 20, 2008 05:10 PM
Montegoodyk
7
Nov 21, 2005 11:12 AM
