1984 Transmission grinding, 1st kicks out
Old Dec 19, 2006 | 12:32 AM
SLC97SR5's Avatar
I have an '84 PU with the 5spd. 1st gear is virtually unuseable, if I hold firm constant pressure on the shifter and slowly let out the clutch at idle it will buck and then drop into gear.
I cannot apply any power whatsoever or it will kick and grind violently.
The rest of the gears feel great with the exception of the occasional grind into 2nd while on a downshift from 25mph.
I've been told it could be bad synchro's or a bent/broken shift fork.
How do I know if the clutch is worn and how do I adjust the free-play...any other adjustments?
The truck is stock with 235/75/15's and 122,xxx miles.
Old Dec 19, 2006 | 02:52 AM
Angus1's Avatar
sounds like a shift fork to me, and there is no adjustment on your clutch it hydro and does it automatic kinda like disc brakes.
Old Dec 19, 2006 | 06:28 AM
titicaca's Avatar
syncro is shot.....
Old Apr 12, 2008 | 12:13 PM
Flachevota's Avatar
does anyone know where to buy, transmission gears?? Any help would be great. 1984 Toyota Pick-up
Old Apr 13, 2008 | 08:28 PM
84sr5yoty's Avatar
Have you replaced the shifter seat and bushing? They are known to cure the problems that you're having.
http://www.brian894x4.com/Shifter.html
http://toyota.off-road.com/toyota/ar...shifter%20seat
jashoeuh
Nov 18, 2024 08:08 AM
mskalmus
May 28, 2017 07:51 AM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
Tigbucket
Jul 30, 2015 07:29 PM
mengquis
Jul 13, 2015 10:39 AM
