1984 toyota 4x4 wheels
Old Nov 19, 2013 | 01:15 PM
mikeyd6789's Avatar
How do I know if certain wheels will work with my truck?...the front hubs and what not.
Old Nov 19, 2013 | 01:43 PM
Stetson_md's Avatar
http://www.lugpattern.net/Toyota_Bolt_Patterns2.htm
Any particular rims your looking at?
Old Nov 19, 2013 | 01:47 PM
mikeyd6789's Avatar
I'm not really concerned about lug pattern...more of how deep the back of the rim is. To fit my 84 straight axles up front.
Old Nov 19, 2013 | 02:05 PM
Stetson_md's Avatar
3 3/8" is factory
Its called backspacing if you want to research it
Old Nov 19, 2013 | 02:07 PM
mikeyd6789's Avatar
Factory for what?... For instance stock 1990 4x4 will not fit my front without rubbing.
Old Nov 19, 2013 | 02:35 PM
85toy4runner's Avatar
3 3/8" is toyota factory solid axle wheel backspacing . 1986 and up toyota IFS wheels have a back space of over 4 inches and will rub the front without wheel spacers. if you have cross over steering IFS wheels will work and not rub
Old Nov 19, 2013 | 06:41 PM
Stetson_md's Avatar
What 85toy said
Old Nov 20, 2013 | 07:52 PM
mikeyd6789's Avatar
Thanks for clearing that up for me!
Old Jan 3, 2014 | 03:51 PM
mikeyd6789's Avatar
Found some wheels with backspacing 3.75. Will that work? Jegs D widow wheels.
Old Jan 3, 2014 | 04:43 PM
cman1's Avatar
yes,thats what im running with 33s right now.
Old Jan 3, 2014 | 04:45 PM
mikeyd6789's Avatar
Thanks man...found a good deal on some... Gonna go with them!
Old Jan 3, 2014 | 04:48 PM
dropzone's Avatar
Fossilized
Not necessarily, even with a conversion to IFS calipers and FJ rotors some may rub the caliper.
Best way to make sure a rim will fit is a 10 minute test fit..
Old Aug 17, 2014 | 12:06 PM
SniboRyder's Avatar
This is my first post on yotatech. I've done so much work to my truck through this site, its really been a great resource!
I recently finished the v6 caliper/fj rotor upgrade on my 85 SFA 4runner and current 15x8 3.75" bs wheels will not clear the caliper face. I knew this would most likely happen after reading through the forums.
I would rather buy new rims then run spacers on the front. I've read through explanations about backspacing and offset. My question is if my calipers extend out 1/2" would I need wheels with a larger bs like 4" or do I need a wheel with enough negative offset about -13mm, which as I understand would create a larger "dish" to clear the face of caliper? I have to order rims to test fit and need to know exactly what I need.
Old Aug 17, 2014 | 10:02 PM
rokblok's Avatar
I just run 1.5" spacers, which matches the IFS rear I put in.
Any particular reason you don't want to run spacers?
Old Aug 17, 2014 | 11:02 PM
SniboRyder's Avatar
People seem to be split 50/50 on spacers. Some love them and some hate them. My rig is my DD and I wouldn't mind putting some better looking rims if I could find them for $50-$70 a pop but the more I look and ask around it seems the grinder, spacers or both.
I take it you like your spacers? Did you ever run the spacers before your rear was done and if so did you notice anything different like the tracking of the truck or wear of the tires? I have the TG spacers in my shopping cart but am hesitant to pull the trigger just yet. Even if I don't have the IFS rear, would you recommend the 1.5" spacer? I would like to do the conversion but it would be a while before it gets done.
I'm probably overthinking this whole thing. I appreciate the response.
Old Oct 5, 2014 | 07:37 AM
Liljoe3000's Avatar
there's no reason to be scared of running spacers, if installed correctly you should have no problems.
Falcon78
Engine Swaps
Jul 1, 2015 05:01 PM
Crazy_Guy97
12
Jun 24, 2015 04:02 PM
crash
21
May 28, 2005 10:11 AM
Corey
24
Jul 15, 2002 07:53 PM
Krash
10
Jul 13, 2002 09:21 PM
