1984 diesel 2.4 manual transmission fluid
Old Dec 8, 2013 | 07:55 PM
Andrew James's Avatar
Searched but maybe I didn't use the right keywords. I have a Isuzu Rodeo with a 1984 Toyota diesel 2.4 mated to a Toyota 5 speed and transfer case. Could anyone tell me what the name of the transmission is, transfer case and what kind of fluid/oil they use? I assume a sort of gear oil and how much the transmission holds and how much the xfer case holds? Thanks guys!
Another thing, the doohickey mabob that goes from the alternator/vacuum pump to the block is leaking oil. What is that and what should I do to fix it?
Old Dec 9, 2013 | 02:20 PM
Does nobody know the answer to this at all??
Old Dec 9, 2013 | 03:22 PM
85toy4runner's Avatar
Hello, im not sure if people can direct you in the proper manner cause they dont know what trans and what transfer case you have. I think you would be safe on running redline mt90 gear oil in both trans and transfer . I think if you buy 6 quarts you would be ok but you might want to buy 7 just in case . its hard to tell what trans you have and transfer case without seeing pics or knowing what they came out of
Old Dec 9, 2013 | 03:24 PM
I figured its what ever trans often was attatched to a 4cyl diesel toyota 1984... I assume there must be only one option...
Old Dec 9, 2013 | 03:26 PM
thats what I was thinking just now to
Old Dec 9, 2013 | 04:49 PM
its probably a G52 Transmission with a Gear Drive RF1A transfer case.
in that case you could use redline mt90 gear oil in both trans and transfer
Old Dec 9, 2013 | 07:15 PM
rokblok's Avatar
Yes. Mt90 is safe for both
smthwsn357
May 1, 2024 07:28 AM
jasonty
41
Dec 23, 2018 01:00 PM
HookahRoo
Jul 20, 2015 07:06 PM
tobylab
Diesel Swaps
Jul 17, 2015 06:51 PM
Poncho0206
Jul 10, 2015 06:21 PM
