1984 22R Crank pulley slinging oil
Old Dec 17, 2006 | 08:56 PM
SLC97SR5's Avatar
I just bought an '84 that is leaking oil around the Crank pulley. It is slinging oil onto the skid plate.
I changed the oil recently upon purchasing with Chevron 10w-30. I accidentally over-revved to 7k. That's when I noticed the oil.
Have I blown a Crank seal? What is involved in changing this?
Old Dec 17, 2006 | 09:19 PM
deserttoy84's Avatar
WT*!!! accidently overevved to 7k?? are you sure its just slingin oil and not about to blow up? if you need a new front seal i got a brand new one for a 22r. to change the seal you pull off the belts, then the bottom pulley which you need to take off the skidplate to get to it, then take off the big center bolt which is the only pain in the butt. then you can pry out the old seal if thats what it is. if it isnt then it might be the oil pump seal. Try running regular castrol gtx oil, its the best for these engines.
Old Dec 17, 2006 | 09:32 PM
SLC97SR5's Avatar
That was my next question; will our engines go that high? My tach is a little jumpy/bouncy, so it may not have been that high. It may have overshot itself but the needle definetly hit 7k.
Old Dec 18, 2006 | 10:49 AM
DudeBud's Avatar
yes they will my 22r used to hit 7k back in the day and its still running
Old Dec 18, 2006 | 02:41 PM
4runnerx3's Avatar
The front seal would be the black part you see on the front of the oil pump.
Old Dec 19, 2006 | 12:26 AM
SLC97SR5's Avatar
Thanks guys, I've pressure washed the skid plate and after a 15min drive home not going over 5k I noticed a very light spray on the skid.
Sounds like it's not too bad...what's the torque on the crank nut?
Old Dec 19, 2006 | 11:14 AM
4runnerx3's Avatar
116 ft-lbs
Old Dec 19, 2006 | 11:47 AM
surf4runner's Avatar
^to put it on. to take it off its ~ 5000 ft-lbs
Old Dec 19, 2006 | 12:00 PM
PirateFins's Avatar
Just put a long breaker bar with a socket on the ground MAKE SURE IT IS TOUCHING THE GROUND ON THE DRIVERS SIDE, pull the coil wire that goes to the distributer. Crank motor for a short burst. Crank bolt will be loose. Remove breaker bar and socket after tightening back up and before starting.
Old Dec 19, 2006 | 01:18 PM
titicaca's Avatar
check the oil pump o ring too. its a little tricky to get back in the groove on the timing cover but if you use a little grease it will help it stick a little better.
as for the pulley , you might need to get a repair sleeve also. its a metal sleeve that goes over the pulleys seal mating surface to keep any grooves worn into the surface from damaging the seal.
Old Dec 24, 2006 | 10:19 PM
SLC97SR5's Avatar
Would this leak be a good canidate for some Lucas? What "stop-leak" products have you guys had success with?
Old Dec 25, 2006 | 07:22 PM
4runnerx3's Avatar
You might need to put a sleeve on the seal side of the crank pulley. If the crank seal is worn or the crank pulley has a groove worn in it, no stop leak will fix it.
Old Dec 25, 2006 | 09:05 PM
Tool Pants's Avatar
I replaced that seal many years ago and no leaks since then. I did not have a groove.
Went to Pep Boys and they have a kit with all the parts. In fact I think there were more gaskets then were actually needed. Might have been for the water pump.
Getting the bolt off is the trick. I used the breaker bar method. Do pull the coil wire. Getting the bolt back on and torqued is also a trick. It has been so long. I think I had the radiator out and used an electric impact. It think that bolt gets tighter as the engine runs. I was not able to use a torque wrench because the crank would move even with the manual transmission in gear.
I would not put any crap in the oil to fix a worn seal.
My local wrecker has this engine on a stand. You can see the seal.
Old Dec 26, 2006 | 10:09 AM
SLC97SR5's Avatar
Hey thanks for all the great pic's&tips guys!! I'll let you know when I do this.
Old Sep 4, 2007 | 11:35 PM
SLC97SR5's Avatar
Long term update:
The seal quit leaking about 2 weeks after I posted this, I didn't use any stop-leak or Lucas. I'm guessing after sitting a year the seal may have shrunk/driep up and after several hot/cold cycles it started doing it's job.
Regardless, thanks to all who responded.
Old Sep 5, 2007 | 07:25 AM
Thats good. If it ever starts leaking again then just replace the seal. a bottle of stop leak seriously would cost more money then buying the seal.
Old Sep 5, 2007 | 08:24 AM
XtraSlow_XtraCab's Avatar
Does that Lucas stuff actually work? Personally, I don't believe in all that leak-stopper/additive crap. If it's leaking, somethings wrong.
And if there's a chemical chunky enough to stop a leak, I don't want it near my valves!!!
Old Sep 5, 2007 | 08:50 AM
it works alright. If you got a really old motor using a bunch of oil then i would use it.But if your motor is in good shape i would just fix whatever is leaking. only thing ive ever put in my engine was seafoam to clean it out(crankcase and intake)
Old Sep 7, 2007 | 10:24 PM
slus's Avatar
I know you already have the problem fixed, but for future readers, the crank seal is easy to replace. The hardest part is messing with the belts. As far as sleeves go, there is really no need for them. If you buy a replacement from Toyota, the gasket is ~2mm shorter, placing the seal on a fresh, non grooved surface. Napa replacement main seals are like this too.
Old Sep 11, 2007 | 11:05 PM
Demon415's Avatar
If you plan on mudding this truck you should replace this seal! Its really not that hard to do. I ran my truck into a three foot deep clay pit in the pine barrens in NJ and it made that very same seal leak. I went from no leaks to lossing all my oil in two days. I went to pepboys and bought that front gasket kit thinking it was the timming chain cover. After six hours in my front driveway i was good to go.
