Where to find a tie rod center link?
My center link between the two tie rod ends is bent pretty badly. The truck needs to have an alignment done altogether but I would like to replace the center link first.
I know there are lots of cross over/high steer options but i'm trying to keep this 4wd stock or as near to stock as I can. What can i say they just look cool stock :-P
Anywho here is the picture of what i am looking for:
Junk yards are empty, local napa had one that fit an 84 runner but the size was all wrong and it wouldn't fit the tie rod ends. Thought about getting new tie rod ends as well (that would fit the 84 bit) but those have a different angle and not sure they would pop into the knuckles right.
Found one an @ http://shop.rareparts.com/smtp/shopdisplaycategories.asp?iyear=1983&imake=0054|TO YOTA&imodel=1253|PICKUP&iproduct=0049|STEERING,%20 GEAR,%20PUMP%20&%20COMPONENTS (part 26750) but 200 bucks seams a little steep and it says that you need 2?
Putting this out there to see if anybody knows where i can pick one up! Much appreciated!
I just installed a Heavy Duty tie rod from Sky Manufacturing.
http://www.sky-manufacturing.com/cgi...y=TOY-HDTR-001
It's way stronger than stock and It only cost a little bit more than if you were to replace the rod and both ends with new stock parts (if you can find the rod). Like Slacker said above, use a stronger FJ rod and ends (I think you have to ream your steering arms for the FJ rod ends to fit) or get Sky's kit which straight bolt on.
Well the Napa by the house had one for mine but they had to order it I hit a big dog going to work and screwed mine up bad but yeah my Napa had one so maybe check again and for a new damper and the center link and shipping was $230
sandyota
Feb 4, 2021 11:16 AM
Sep 4, 2015 09:27 AM
