Pre 84 Trucks 1st gen pickups
What did he break on my truck????
Old Apr 7, 2008 | 04:50 AM
Quattro15's Avatar
I've got an 82 Yota pickup. My little brother was using it in the woods and while going up a steep hill, probably at more speed than necessary, something popped in the trannie and now something isn't hooking up for the truck to either get in gear or something?? The truck won't move, engine is fine, something in the transmission.
What should I do?
Thanks!
Old Apr 7, 2008 | 06:24 AM
rowdy235's Avatar
clutch most likely. Something letting go in the tranny like that isn't likely. T-case in gear?
Old Apr 7, 2008 | 09:04 AM
Quattro15's Avatar
I would imagine the Tcase was in gear....I'm not 100% sure on that one though.
Old Apr 7, 2008 | 09:05 AM
Quattro15's Avatar
And where can I get a clutch for this old beast?? I'd imagine I could put it in myself.
Old Apr 7, 2008 | 09:46 AM
TOYOTA 1's Avatar
yes it not hard to install. im thinking marlin HD!
Old Apr 7, 2008 | 10:05 AM
Quattro15's Avatar
Marlin HD.....
Which is????
Old Apr 7, 2008 | 01:05 PM
dropzone's Avatar
Fossilized
marlincrawler.com a pretty good source for parts click here: Clutch page
Remote chance but the 21 spline output shaft in the transfer case has also been known to let go under a severe load. Possible the throw out bearing...
Old Apr 7, 2008 | 01:37 PM
gilby4runner's Avatar
can you put it in gear and it just wont move or will it not let you put it gear?
Old Apr 7, 2008 | 02:39 PM
brooklee1000's Avatar
Rowdy235 has the right idea. I have had my stick shift knock the t-case out of 4wd a few times. Check that before getting excited about clutch parts. Have you gotten underneath?---could be a u-joint. If not, then clutch might be the next thing to check. gilby4runner has the right question above too.
Old Apr 7, 2008 | 04:45 PM
Quattro15's Avatar
I'm pretty sure it can go into gear....just won't go anywhere. I'll check for sure tomorrow.
Thanks for the help so far.
Old Apr 7, 2008 | 07:42 PM
mackio's Avatar
sounds like the clutch if its in gear but wont move
Old Apr 7, 2008 | 08:15 PM
Sked's Avatar
Does any power get to the tranny? Like if you switch gears with no clutch does it grind? If not its the clutch, if so then its your Tcase. Might be in Neutral or blew it up
Old Apr 7, 2008 | 08:39 PM
rowdy235's Avatar
^^ good call, let the clutch out, and try to shift into a gear (i'd pick reverse). If it slips in we got a clutch problem, if it grinds we got a problem behind the clutch.
Old Apr 8, 2008 | 09:22 AM
Quattro15's Avatar
Ok...so I just got done playing around with the Rebel....my '82 pickup is a "Rebel Edition" I dunno if anyone has seen one of these before. And NO I'm not racist for the record.
Anyhow....she goes into gear and drives. I don't know what my bro was talking about with it being broke. This truck seems to heal itself sometimes though, quite odd.
The only thing I can think of is that the shifter has a lot of play in it. Like...it'll go into gear, but you can swing the shifted back and forth quite a bit while it's in gear and when out of gear....to be more specific you can "twist" the whole shifter.
What would have broke to allow this?
Old Apr 8, 2008 | 09:34 AM
85toy's Avatar
idk what broke or if it is just worn out but a rebel edition is rare, cool truck.
Old Apr 8, 2008 | 09:36 AM
Quattro15's Avatar
Yeah.....that yota is a beast!! The Rebel flag painted on the hood gets some harsh looks though.
I want to make a real off-road truck out of her but the Rebel has a lot of rust on it. Fender flares and bed are pretty rusted. I don't know if it's worth the investment. I'd probably have to totally rebuild it.
This truck was my father's, he bought it new in '82 for $5,000 and it has NEVER broke down until my little bro thought he had busted the trannie up. I took it for a drive today though, runs fine.
It's only got like 160k miles on it, but it's been a wood truck for the past 10 years or so, so they are hard miles for sure! Just debating if I want to put the money into it or not.
Old Apr 8, 2008 | 02:12 PM
dropzone's Avatar
Fossilized
Post up a picture of the Rebel Edition, that is something I have not seen.
Your truck seems to be suffering from the most common ailment to stick shift Toyota. The Shifter bushing has probably finally broken up. It is about $20-25 worth of parts and 10-15 minutes to fix. Should just be able to take off the shift boot and remove the stick, drop in the bushing and reinstall the stick.
Here is a link that shows the part: http://www.marlincrawler.com/docs/sh...eat/index.html
If your truck is suffering from a broken shifter lever seat this is a great write up: Shift Lever Seat Replacement Write up
Old Apr 8, 2008 | 04:19 PM
Quattro15's Avatar
I'll take some pics tomorrow, be forewarned though I have used this truck for all it's worth, it's def not a pretty shiny truck. It has quite a few dents and dings.
Old Apr 8, 2008 | 04:26 PM
rowdy235's Avatar
^^ the best do
Old Apr 8, 2008 | 06:05 PM
85toy's Avatar
Originally Posted by rowdy235
^^ the best do
Tru dat.
