Pre 84 Trucks 1st gen pickups
Weber setup
Old Feb 19, 2011 | 10:38 AM
NMElkaholic's Avatar
never had a shroud sense i have owned it... I will prolly go down to the salvage yard and pick one up.
Old Feb 19, 2011 | 10:55 AM
mightymouse's Avatar
scribed for reference. good info here. XXX you're the man.
Old Feb 19, 2011 | 01:46 PM
JonnyBoy's Avatar
I've driven in 110 degrees in 4low and not had it overheat without a shroud. It would get hot at highway speeds cause the radiator was clogged, but never a problem at low speeds. I just replaced it with a 3 row for an '84 4wd.
Old Feb 19, 2011 | 02:42 PM
Yea, I replaced mine as well not to long ago... that thing is runnin so good now! best money I have ever spent!!! very happy with the outcome of this project!!
Now I need to work on my right front hub.... makes an aweful squel when I lock it in 4 wheel drive... i am guessing the spring is broken in there?? you guys know where i can get a rebuild kit for those?? then i will prolly get a rebuild kit for the front axle.... etc.. etc....
Old Feb 20, 2011 | 05:42 AM
  #25
Gov't Mule's Avatar
I recently did a front axle rebuild on my rig (hub dial to hub dial) and got all my parts from TrailGear.
http://www.trail-gear.com/axles-and-service-parts
Old Feb 20, 2011 | 12:43 PM
  #26
Thanx for the website i will give them a look.
kawazx636
Oct 6, 2021 03:03 PM
4runnerFireman
Sep 29, 2015 06:24 AM
voiddweller
Sep 28, 2015 11:21 PM
Keithstoyota
Sep 27, 2015 07:29 AM
