Pre 84 Trucks 1st gen pickups
Water line questions
Old Oct 8, 2014 | 08:05 PM
msane99's Avatar
I also switched to newer throttle linkage because I never could get my 2 barrel to open up right with the linkage from 79/80 (like yours). get someone inside truck while its not running to floor it while you look into carb to see if 2nd barrel is opening right. I removed stopper (governor) from behind accelerator pedal first, still wasn't great. Finally put newer accelerator linkage setup and it adjusted out nicely.
M
Old Oct 8, 2014 | 08:25 PM
Yoda38052's Avatar
Only question I have now is, do I plug fuel return line going back to fuel tank?
Old Oct 9, 2014 | 05:08 AM
msane99's Avatar
I plugged the fuel line that returns to tank that is paired with a brake line. you aren't talking about those yellow lines off pump right? you have three nips on fuel pump two go to tank one to carb. I left all that alone. but I had another fuel line that was paired with brake line down frame and I capped him.
Old Oct 25, 2014 | 01:41 PM
john1320's Avatar
moved
Last edited by john1320; Oct 25, 2014 at 04:49 PM. Reason: please remove, moved to another section
the1998sr5
15
Jul 14, 2020 08:35 PM
thefishguy77
Jul 30, 2015 10:59 AM
Poppie51
Jul 16, 2015 06:16 PM
87turboPA
Jul 12, 2015 07:49 AM
87turboPA
Jul 9, 2015 05:58 AM
