Pre 84 Trucks 1st gen pickups
Trouble at 4,000
Old Aug 31, 2015 | 05:59 PM
jimmyjoebillybob's Avatar
Trouble at 4,000
I ve got an 81 4x4 rebuilt 21RU 32/36 weber and tri y header. a week ago it started to act up. I can take off and it runs great til I hit 4,000 RPMs then it acts like its runnin out of gas. I ve replaced the fuel pump 3 times, two coils, cleaned the carb and all new fuel lines, rubber and steal, and still cuts out at 4 grand.
Old Sep 1, 2015 | 05:11 AM
83's Avatar
83
Maybe someone put a governer on it...
But seriously...I don't know much about that engine. I wonder if the carb is incorrectly jetted? Or out of adjustment. I'm sure when you were working with all the fuel stuff you replaced the filter, including the one in the tank.
Old Sep 1, 2015 | 09:46 PM
yep new filters and it had been runnig great for months before this. gonna pull the carb again 2maro and go through it
Old Dec 31, 2017 | 07:37 AM
Trouble shooter's Avatar
Have you checked your timing
these. Engines are real picky about fast timing on top end
Old Dec 31, 2017 | 10:44 PM
Co_94_PU's Avatar
Buy an hour at/on the local dyno. This will give you info on the fuel mixture/ AFR ratio. They likely have the hardware to monitor timing (oscilloscope) and can tell you if there is something wrong with the vacuum advance ect.
PS, just saw this is a three year old post ffs, ug.
Longbed 90
Mar 11, 2019 12:38 PM
voiddweller
Oct 2, 2015 07:47 AM
Matthew Perez
Sep 28, 2015 05:43 PM
Boomer8404
Sep 17, 2015 07:59 AM
128keaton
Sep 3, 2015 05:09 PM
