Pre 84 Trucks 1st gen pickups
Toyota springs
Old May 15, 2007 | 05:35 PM
freeskier125's Avatar
Toyota springs
I have a 81 toyota pickup that I plan on putting 63" chevy rears in. What springs should/could I use for the front?
Old May 15, 2007 | 05:41 PM
Toy-SkiTzo's Avatar
use rears up front
2 rear packs cut up into one pack they flex awsome and there are really cheap
here is my truck with RUF
http://www.pirate4x4.com/forum/showthread.php?t=265669
Old May 15, 2007 | 06:06 PM
did you use chevy springs in the rear or a 3" lift spring, or doesnt it not matter because they would be about the same? do you need to make shackles or anything?
Old May 15, 2007 | 06:07 PM
Island_Yota's Avatar
^ you forgot to mention it moves your axle 2" forward which means you will need Hi-Steer, a longer front driveshaft and ditching the torque arm not to mention the pinion angle too. RUF swap isnt as cheap as most say, PLus with the 63" chevy rear springs you wont see any lift unless you add 3" lift blocks and mega shackles, I have to admit the trucks ride really nice with them though and flex like no other.
Old May 15, 2007 | 06:16 PM
Originally Posted by Island_Yota
... with the 63" chevy rear springs you wont see any lift unless you add 3" lift blocks and mega shackles.
do they only improve ride/flex ability and no lift? what if you used a dual shackle set up, or is that not the way to go? what about using the stock chevy shackle in there too?
is there a setup where you wont have to switch to Hi-steer or change anything up front?
Old May 15, 2007 | 06:22 PM
Toy-SkiTzo's Avatar
o ya sorry i forgot about it moving the axle.
but the axle is moved about 3-4in forward and you will need highsteer. the chevy springs will give some lift my freind chris has RUF and chevys and his truck looks a little low in the back but not bad
Old May 15, 2007 | 07:00 PM
Yota Tony's Avatar
Chevys give about 3" if they are in good shape.
RUF and chevys are cheap when compared to a lift kit.
Old May 16, 2007 | 02:38 PM
if i used 2.5" lift YJ leafs in the front will i need to change any steering stuff? will a stock drive shaft be long enough?
Jun 1, 2021 01:51 PM
Sep 4, 2015 09:27 AM
Nickdigg
Jul 7, 2015 06:04 AM
toyoda8488
Jul 5, 2015 10:18 PM
