Pre 84 Trucks 1st gen pickups
View Poll Results: what do you use your 1st Gen truck and what size tire to you run
Daily Driver/weekend trail runner
68.18%
Rock crawler
4.55%
mud runner
4.55%
stock size tires
0%
31's-32's
31.82%
33" tires
27.27%
35's-37's
40.91%
38" plus
0%
Multiple Choice Poll. Voters: 22. You may not vote on this poll
Tire size and stability poll
Old Feb 11, 2011 | 09:02 PM
SC81YOTA's Avatar
Hey all. Kinda new here on the forum and had a simple question. What size tire do the majority of you run on your first gens, and what kinda wheeling do you do (Mostly mud, rock crawl, trail ride, etc). I myself do alot of wheeling in the southeast (US) mountains. Not alot of rock crawling but there is alot of steep hills with little to no turn around spots at the end of the trails. I like to keep a low center of gravity so I run an OME lift with one leaf removed and 32" tires with arb lockers front and rear. Even with this small amount of lift I find myself rocking back and forth with only two tires on the ground. Im always looking to upgrade my rig so give me what you got. Thanks
Old Feb 11, 2011 | 09:38 PM
dropzone's Avatar
Fossilized
added a poll for you
Old Feb 11, 2011 | 10:36 PM
SC81YOTA's Avatar
Fantastic!! Thankee
Old Feb 12, 2011 | 04:37 AM
INFINITY's Avatar
i run trails when i find time. but besides my wife's pilot my 80 is my weekly driver. highway, hunting, light trails and rock trails. my 80 b4 the duals wheeled with my skinny tires as good if not better than my 94 sas. due to the weight of the truck and skinny tires = more traction.
Old Feb 12, 2011 | 12:30 PM
4x4YOTA's Avatar
I run 33s on my stock 81 and use the same tires for trail & high way
Old Feb 12, 2011 | 12:39 PM
GreenMonster80's Avatar
I run 35's with about 5 inches of lift, and I've had it to about 27 degrees of horizontial lean before it really got hairy. I had it to 32 degrees but i had to use a snatch block and winch to keep me from rolling down a sidehill. I'm not quite sure if that's what your looking for though.
Old Feb 12, 2011 | 01:59 PM
SC81YOTA's Avatar
Exactly what im looking for, thanks!!
Old Feb 12, 2011 | 02:30 PM
Nimyad's Avatar
If you want to be able to sidehill the best run 40s with maybe 5 in of lift. I had about 3.5 in lift with 35s on mine but i didn't do any fender trimming
Old Feb 12, 2011 | 03:41 PM
camo31_10.50's Avatar
if you want stability, as in not rolling..then go WIDER.
a more flexy suspension will help keep all 4wheels on the ground longer.
djpg2000
Nov 11, 2020 04:56 AM
jgallo1
Oct 26, 2015 06:39 PM
Gravel Maker
RuffStuff
Aug 6, 2015 04:27 PM
Luvmeye22re
Aug 4, 2015 03:53 PM
coffey50
Jul 28, 2015 10:55 AM
