Pre 84 Trucks 1st gen pickups
Tire Fitment?
Old Feb 5, 2007 | 05:48 AM
Yota Tony's Avatar
Tire Fitment?
Got an 82 Pickup and I want to toss some rubber on it to replace the **** that's currently there.
It's stock ride height far as I know. Can I toss some 33x12.50 tires on it?
Will I need to change the rims?
I'd like to run 37x12.50s once I do the suspension over, should I widen the axles or use spacers or what?
FYI, the rear has a flat bed.
Old Feb 5, 2007 | 07:44 AM
4Crawler's Avatar
Likely 31x10.50 without a lift. You can fit 33s with a few inches of lift (suspension or body). Stock rims are likely 6" wide, a 33x10.50 works well on those:
http://www.4crawler.com/4x4/BFG_AT_KO.shtml
Probably need an 8" rim for 12.50s.
Old Feb 5, 2007 | 07:54 AM
Yota Tony's Avatar
I know I'll need a wider rim.
What I'm wondering about is backspacing on the rim to make it all work with my truck.
Old Feb 5, 2007 | 08:03 AM
4Crawler's Avatar
Max is around 3-3/4", stock is 3-3/8", less is wider and better for stability, but may require more lift to fit a given tire.
Old Feb 5, 2007 | 09:11 AM
Yota Tony's Avatar
So if I go to 3-3.5" BS, I'll need to wait till I lift it then.
Thanks for the info!
1uzRunner
63
Nov 10, 2018 03:58 PM
Williamemslie
14
Oct 5, 2015 09:28 AM
AkitaDog
Sep 3, 2015 09:01 PM
128keaton
Sep 3, 2015 05:09 PM
matthew138
Sep 3, 2015 08:21 AM
