Pre 84 Trucks 1st gen pickups
Sucking air??
Old Jan 24, 2012 | 01:12 PM
1981 4x4's Avatar
Sucking air??
My toyota is suckin air from somewhere ive replaced fuel pumps fuel filters ran whole new fuel line from tank and put 10 gal of gas in and still bubbling filter i pressure tested for cracks in the pickup assembly that goes in tank. Any one ever had any problems out of the cap that screws into top of fuel tank where fuel lines hook to pickup?
Old Jan 24, 2012 | 02:50 PM
igotit's Avatar
is your truck running bad,or is performance affected by the air in the filter?
try a new filter,maybe you got a defective filter.
Old Jan 24, 2012 | 04:47 PM
slacker's Avatar
is it stalling randomly ? , whats happeing when it's "sucking air "
Old Jan 24, 2012 | 05:35 PM
1981 4x4's Avatar
It runs like a champ for about 5 minutes then will stall randomly and wont start or run . then like if you leave it for awhile and come back same thing start . if you choke it with your hand to run it for short time or idle theres constant bubbles in the filter like its suckin air somewhere an put a new fuel filter on today
Old Jan 24, 2012 | 06:33 PM
igotit's Avatar
my old 22r done the same thing,once started....ran great.if left parked for more than 8 hours...had to pour gas to fire up.
never solved that issue,just swapped out motors.
post your findings.
Old Jan 25, 2012 | 07:02 AM
slacker's Avatar
just went threw this with a customers vehicle .. he had replaced everything ! carb, lines , pump (3 of them) , filter, pickup tube all , and was still randomly stalling and fuel empty filter . turned out to be the pre filter on the pickup tube in the tank , it had fallen off on the original , and was not replaced on the new one . installed this piece , and fixed his problem
Old Jan 25, 2012 | 04:12 PM
1981 4x4's Avatar
wherd u buy the pre filter pickup
Old Jan 25, 2012 | 04:17 PM
slacker's Avatar
dealer , but I have also seen them on ebay
Old Jan 25, 2012 | 04:43 PM
1981 4x4's Avatar
What about that causes it to stall? Mine has one of the bottom screen like sleeves busted out.
Old Jan 25, 2012 | 05:09 PM
1981 4x4's Avatar
was the little filter you replaced a small cylinder shaped filter with screens in square sections of it?
Old Jan 26, 2012 | 07:07 AM
slacker's Avatar
yep .. thats the one .
I'm not positive on why it causes air into the system , other then possable debris blocking the intake hole ? but this was the cure for the unit we worked on
Old Jan 26, 2012 | 03:58 PM
1981 4x4's Avatar
Alright thanks ill check it out and post if it fixes it
Old Jan 26, 2012 | 04:12 PM
slacker's Avatar
no worries , glad to help , hope it cures your problem
1uzRunner
63
Nov 10, 2018 03:58 PM
old87yota
Sep 9, 2015 12:39 PM
some drunk guy
Sep 4, 2015 11:55 PM
Squigglez
Sep 4, 2015 07:33 AM
calderp
Jul 27, 2015 09:58 AM
