Pre 84 Trucks 1st gen pickups
Shifter Bushings or no Shifter Bushings
Old Dec 10, 2006 | 01:28 AM
joshd's Avatar
On my 80 4x4 where the shifter bolts onto the tranny case at the top, right below the rubber boot, there is tons of slop in the bolts (about 3/4"). Is there supposed to be some rubber bushings in there? It doesn't seem like you can tighten the bolts anymore, so that is what I am assuming? If there is supposed to be some bushings in there, where do you purchase them?
Old Jan 8, 2007 | 07:03 AM
4XTOYOTAX4's Avatar
If I understand the problem correctly, then yes it should bolt solidly to the trans. Sounds like you need shorter bolts, you should be able to get those at a parts or hardware store. If im wrong let me know.
kawazx636
Oct 6, 2021 03:03 PM
mwisham
May 26, 2021 02:51 PM
live4soccer7
May 11, 2016 06:52 PM
punks_is_4x4
Feb 26, 2016 04:29 PM
briholt
Sep 20, 2015 10:26 PM
