Pre 84 Trucks 1st gen pickups
set'en toe
Old Dec 16, 2010 | 10:41 AM
1stGenBen's Avatar
set'en toe
did highsteer on my 82 last night (finally ) and tring to tune it in the best i can. going to be a while till i can take it to get aligned. i had a couple stock rims (no rubber) and bolted them on, pulled a tape and set it so there in 1/16 toe in from outside to outside. sound right? goes down the road stright and doesn't wonder. any other tips? thanks
Old Dec 16, 2010 | 10:48 AM
scuba's Avatar
Sounds like your on the money....
"Factory spec is 1mm +/- 2mm which equates to -1mm to +3mm, 3mm = 1/8" and with a larger diameter tire, 1/8" is reasonable."
http://www.4crawler.com/4x4/CheapTri...html#Alignment
Old Dec 16, 2010 | 10:53 AM
1stGenBen's Avatar
the truck sits on 35's most of the time, 37's when its hammer time! good deal, still going to get everything double checked one of these days...
muddpigg
Nov 2, 2015 05:36 AM
fabing455
Sep 7, 2015 08:08 AM
