Pre 84 Trucks 1st gen pickups
Rebuilding 81 pickup with an 85 22r ?s
Old Jan 9, 2018 | 03:38 PM
xhacks's Avatar
Hi all,
Im new to this forum, and im looking for a few wires to put in a backup siren and my alarm.
First one is the neutral safety wire that is ground when in neutral,
Second is the parking light wire on the switch and is it + or ground trigger,
Last one is the reverse sense wire and is it + or ground trigger
I also need some help troubleshooting the blower motor for the heat in the cab (A/C already deleted) so all im wanting to work is the defrost window vents and the two center vents
Thanks
Old Jan 10, 2018 | 03:16 PM
Lons81's Avatar
To install a backup warning beeper, you basically need one hot wire and a ground wire. I would tie the red positive wire downstream of the back light switch Red-Blue going to your backup lights. Run the ground wire to anyplace close to the beeper mounting.
Check your heater tubing going from the heater unit to the vents for correct installation. Is the blower motor working in all speeds?
Old Jan 10, 2018 | 11:49 PM
xhacks's Avatar
The blower is not working at all my uncle was the previous owner and he did something aftermarket on it and i nor he can figure out what was done and how to get it to work again. The switches work but not spinning up the motor, i can test it directly but i havent been able to source the correct wiring diagram to know what wires are for what.
Old Jan 11, 2018 | 07:14 AM
Lons81's Avatar
May be that the resister is bad. PM me with your e-mail address and I'll send a 81 wiring diagram to you
houndawg
Jan 30, 2011 07:43 PM
PeanutRanger
Jun 4, 2007 05:57 PM
fryeguy1983
Nov 3, 2006 02:27 PM
