Pre 84 Trucks 1st gen pickups
Ordering axle rebuild parts and tools.
Old May 9, 2012 | 06:00 AM
limited#279's Avatar
I'm going to rebuild my front axle for the first time and I'm about to order parts, just wondering if I have it all planned out right. I'm doing the front brakes as well. Here is what I have; knuckle parts kit with bearings, knuckle pull scale, 54mm socket, vented rotors, V6 calipers, brake pads and 1" bore master cylinder. I'm not to sure if I need the rear proportional valve or not or if I should order anything for the hubs. What am I missing?
Old May 9, 2012 | 06:20 AM
waskillywabbit's Avatar
If you ditch the lspv you'll need to add a manual prop valve.
You might look into a newer model dual diaphragm brake booster while you're at it.
:wabbit2:
Old May 9, 2012 | 07:44 AM
Outsane's Avatar
some little stuff
brass drift if you don't have one
Lots of grease, brake fluid, rags,
Old May 9, 2012 | 08:24 AM
Bingle's Avatar
Sorry to hijack. Wab, where do you get a manual prop valve, I've never seen them (didn't know they were out there) and would really like to get one.
Old May 9, 2012 | 12:14 PM
:wabbit2:
Thanks for the advise on the prop valve. I wasn't really sure why they were needed, now I know! What year truck should I look for on the brake booster? This is the first I've heard of it.
Originally Posted by Outsane
some little stuff
Good call on the brass drift, thanks.
http://www.davezoffroadperformance.c...ion-valve.html
Old May 9, 2012 | 12:36 PM
You can build your own prop valve setup. Read the Pirate FAQ and hit up Summit Racing.
:wabbit2:
bigjstang
Jun 2, 2025 03:56 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
ItsJustD
Jul 7, 2015 07:49 AM
toyoda8488
Jul 5, 2015 10:18 PM
Vargntucson
Jul 4, 2015 12:15 PM
