Pre 84 Trucks 1st gen pickups
onw wire O2 Sensor
Old Apr 12, 2007 | 03:36 PM
82stock's Avatar
onw wire O2 Sensor
My o2 sensor has one wire and a black and white wire come out of the cab. It's an 82 and I just failed emissions. My CO was way off and I'm sure it's a combination of things but I know I need to hook up the O2 sensor corectly.
Any info on which wire is ground or what would help. Thanks.
Old Apr 12, 2007 | 04:01 PM
4Crawler's Avatar
One wire is for the sensor signal and one for ground. No ground wire on the sensor, but just connect the ground wire to something grounded or to a shield on a shielded cable, that is how my '85 is wired:
http://www.4crawler.com/4x4/O2SensorWireColors.html
Old Apr 12, 2007 | 06:29 PM
82stock's Avatar
Thanks,
I got smart and tested for continuity. And It still smells rich. If I advance the ignition will that make it run leaner? There is an after market cam in the head that I used, it's an LC street performer cam, what should the timing be set at? I have the float and idle mixture set well enough that it shouldn't be that rich. I appreciate the help.
moparbay
Mar 10, 2023 03:50 PM
jb451
7
Oct 7, 2022 06:58 AM
some drunk guy
Aug 3, 2021 06:09 PM
shredder4286
Oct 1, 2015 01:09 PM
zz_denis
Sep 6, 2015 03:43 PM
