Pre 84 Trucks 1st gen pickups
Oil Pan Woes
Old Mar 19, 2011 | 10:56 AM
Gov't Mule's Avatar
Oil Pan Woes
So, I was gonna replace the oil pan on my Trekker today because the one thats on it is dented up pretty bad from being smacked by the axle housing. I bought a good used one off Ebay....BUT, it's different. Same bolt pattern but the sumps are different.
Check it out...
the one on the left is my current dented one. See what I mean about the sump locations. I'm assuming I need a different oil pickup tube assmbly if I want to use the pan on the right??
Can anybody shed some light on this??
Thx,
GM
Old Mar 19, 2011 | 03:15 PM
slacker's Avatar
check your 2WD pan .. should be the same as the one on the left .. right side one is the correct 4WD pan , you will also need the correct 4wd pickup to fit
Old Mar 19, 2011 | 03:21 PM
Gov't Mule's Avatar
I gotta find a 4WD pickup tube then. Thx Slacker.
Sep 4, 2015 09:27 AM
thefishguy77
Jul 30, 2015 10:59 AM
irritech
Jul 27, 2015 05:15 PM
toofly1999
Jul 25, 2015 07:09 PM
ryerye13
Jul 14, 2015 08:27 AM
