Pre 84 Trucks 1st gen pickups
Oil leaking out of vent line filter?!
Old Oct 6, 2010 | 09:01 PM
BoredOutnJackdUp's Avatar
alright so if im understanding you right.
where the vent filter on the valve cover is should be a line into the air cleaner box?
and the back loose line in the valve cover goes where?
and the one going from the dist. cap into the cab is right?
lol sorry im just kinda lost in this.
Old Oct 6, 2010 | 09:06 PM
xxxtreme22r's Avatar
answers in red
where the vent filter on the valve cover is should be a line into the air cleaner box? YES
and the back loose line in the valve cover goes where? there should be a hose barb between the carb and valve cover in the manifold.
and the one going from the dist. cap into the cab is right? As long as it's going directly into the carb YES
lol sorry im just kinda lost in this. No Problem, I know how it is trying to work behind someone else that may not have known what they were doing. I feel sorry for the next guy who gets my truck. LMAO
the hose barb fitting I am talking about should look similar to this. Also I was thinking right about that bvsv, if there is a vacuum line on top of that, then you have to loop a hose or cap them off. You can see that bvsv in this photo as well. Sorry about that confusion:
this is where the distributor vacuum line should go yours might be slightly different because mine is an 87. I have mine going into the original vacuum rail hard line but that goes to the distributor:
Old Oct 6, 2010 | 09:10 PM
Thanks alot. and i did mean cab not carb on the dist. cap. LOL
He said it was for going in water?
Old Oct 6, 2010 | 09:17 PM
not sure what you mean here. you have a vacuum line on your distributor cap? or do you mean the other vacuum port on your distributor body that controls vacuum advance?
BTW I edited the above post, please read it again if you didn't catch it.
Old Oct 6, 2010 | 09:23 PM
  #25
Yeah. in the center. and it runs in to cab of the truck as a breather line?
Its alright, i got it i think. and i need to cap or loop what you have looped?
Im not really up with all these terms.
Old Oct 6, 2010 | 09:26 PM
  #26
if you have a vacuum line that is attached to the top of it yes.
I think I know what you are talking about with the distributor cap now, never seen that done before but ok. lol.
Old Oct 6, 2010 | 09:29 PM
  #27
and does the pcv valve go on the filter place or where i have the loose line?
Old Oct 6, 2010 | 09:31 PM
  #28
you have the PCV valve there already in the right spot on the back of the valve cover the other side of that line goes to that brass piece that I showed you in the photo. The front with the filter goes to the bottom of the air cleaner.
Old Oct 6, 2010 | 09:40 PM
  #29
Alright thats what i thought.
Thanks alot for your help.
Ill check it out tomorrow and let you know what i end up with,
Old Oct 7, 2010 | 03:16 PM
  #30
82blueyota's Avatar
here is how my engine is plumed
Attached Thumbnails Oil leaking out of vent line filter?!-dsc00958.jpg   Oil leaking out of vent line filter?!-dsc00957.jpg
smthwsn357
May 1, 2024 07:28 AM
Eggslinger
Jun 8, 2019 03:32 PM
jakebarrett
Jul 10, 2015 07:15 PM
Coreyr384
Jul 10, 2015 11:13 AM
Gamble_STi
Jul 7, 2015 07:54 PM
