Pre 84 Trucks 1st gen pickups
no power
Old Nov 14, 2015 | 08:06 AM
mlbinmt's Avatar
no power
My 83 r22 pickup is doggy on inclines(lack of power) Continually downshift to resume speed. What could it be? carb, fuel pump. Only filter I could find was inline 12 inches from tank. HELP
Old Nov 14, 2015 | 11:03 AM
wyoming9's Avatar
Red face
No power as compared to what??
Just how long has it had this no power issue. This is the important question!!!
Weight maybe put your truck on a diet .
The fuel filter should be right in front of the fuel tank behind the cab
Old Nov 15, 2015 | 04:41 PM
gillesdetrail's Avatar
Make sure your distributor advance (vacuum) is working, or that the hoses are in good shape.
Old Nov 15, 2015 | 11:57 PM
wyoming9's Avatar
Red face
Small engine @ 120 horsepower when strong and fresh
4x4 vehicle that seems to put on weight if your not careful .
I know in my case that is so very true.
Other then a good tune up .
Then not knowing the size tires you are using perhaps a new set of gears would make you happier .
Old Nov 25, 2015 | 05:44 PM
g3bill2's Avatar
Not much to go on but could be the carb secondary is not opening? It only opens fully after motor is at operating temp but they can stick. When I first bought my truck couldn't get over 40mph with a head wind and slowed traffic on hills I had to work the shaft a few hundred times with WD to get it free enough to open on its own. I still have to oil the shaft every 6 months or it will stick. I rebuilt the carb and primary was plugged also so was a real neglected truck among other things.If you haven't cleaned the carb its a good place to start imo...If motor is not surging, jerking, stalling i'd think the float adjust, pump & filter are ok but look at the sight glass at idle to see if fuel in bowl is too low. (My 4x4 has fuel filter on the wheel well)
So true, large tires will kill power, not good for clutches either
Happy ThanksGiving All....
Old Nov 25, 2015 | 06:16 PM
g3bill2's Avatar
rubrsidedwn
Jul 7, 2016 07:28 PM
LeGussly
Oct 11, 2015 10:32 AM
gentry
Sep 28, 2015 06:16 AM
4Xtruck
16
Sep 24, 2015 09:38 AM
elaketiger
Sep 14, 2015 09:58 AM
