Pre 84 Trucks 1st gen pickups
new weber
Old Sep 7, 2013 | 05:26 PM
rolltide81's Avatar
new weber
hey yall I just blocked all my smog stuff off with the LCE kit .now im installing a new weber 32/36 carb on the 1980 Toyota 4x4 it mentions here to use the 2 spacers to raise the throttle quadrant for better alignment to the carb..so I have to mounting plates for the carb are they talking about spacers that go between the mounting plates?does that mean im missing a couple spacers or are they talkin about adjusting the height of the throttle mounting bracket? really wanna get this done any help would be good I hope im not missin more parts.
Old Sep 7, 2013 | 07:31 PM
84dreamyoda's Avatar
Here's some picture of my 32/36
Attached Thumbnails new weber-image-3407021783.jpg   new weber-image-807574744.jpg   new weber-image-3256111491.jpg   new weber-image-4000006679.jpg   new weber-image-970478889.jpg
Old Sep 8, 2013 | 10:24 AM
1980lwb's Avatar
From the looks of your pictures you're throttle cable mounts on top of your valve cover? If so the spacers they're talking about will not be used for you. If your throttle cable mounted on the intake there are two little spacers to set the bracket up to the height of the carb
Old Sep 8, 2013 | 04:24 PM
warmonger88's Avatar
There should be two holes immediately behind your carb on the intake for your stock linkage mounts. It looks like the linkage you have has been chopped a bit? I would suggest the toyota linkage adapter from weber and make a spacer for yourself that will mount to those two holes and put your linkage in line with your carb.
Old Sep 9, 2013 | 02:02 PM
Rowdydudeman's Avatar
i used 5 washers (to cheap to buy an adapter and my washers work just as good), two closest to the block and 3 on the carb side of the bracket.
Old Sep 9, 2013 | 04:46 PM
rolltide81's Avatar
well got it running the thing runs much better after the de-smog.but now im overheating ..bad im guessin my thermostat isn't opening because I filled the radiator and it over heated and the rad is still full.sound about right?
Old Sep 9, 2013 | 06:17 PM
rolltide81's Avatar
never mind dumb question.
Pri$erulz
Nov 17, 2019 08:03 PM
user 82300
Jan 19, 2016 02:01 PM
highonpottery
Nov 22, 2015 03:57 PM
kawazx636
Sep 29, 2015 08:22 AM
