Pre 84 Trucks 1st gen pickups
new 81 4x4 (new to me)
Old Apr 20, 2009 | 04:56 PM
  #81
4x4YOTA's Avatar
check the salvage yards they usually have a couple...
Old Apr 20, 2009 | 05:37 PM
  #82
dropzone's Avatar
Fossilized
that bed cap looks great...price was right too
great progress...
Old Apr 20, 2009 | 09:22 PM
  #83
toylocost's Avatar
From: Yotatech, because Pirate is too expensive. NorCal.
Let me re-phrase that...
Originally Posted by toylocost
Man I want a free shell so bad. Then I'd have a place to put stuff. Longbed though pita.
Old Apr 21, 2009 | 05:24 AM
  #84
83's Avatar
83
Nice find. I can't find a shell that will actually fit my truck anywhere. I've had one that's about 2" too long for the last couple months. Luckily it's aluminum and was cheap...because over the weekend I took it off & cut the two inches out. We'll see if I can get it back together now.
Anyways, it's looking good! Colorado is nice for finding lots of parts for these trucks. I think that's where mine is originally from.
Old Apr 22, 2009 | 08:47 PM
  #85
4x4YOTA's Avatar
my truck and my friends 80, has same suspension I do but with 35s
what happens when you drive a friends truck that your nt to sure about
Old Apr 22, 2009 | 10:30 PM
  #86
4x4YOTA's Avatar
looking for some parts...
4.56/4.88 4cyl third with spool
4.56/4.88 gears
4cyl spool
also
15x7/15x8 white wagon wheels with 3.75"/2.5" BS
1.5" wheel spacers (2 pair)
twin stick (top shift)
Old Apr 30, 2009 | 08:56 PM
  #87
4x4YOTA's Avatar
so I'm going to pick up my V6 rear axle tomorrow with 4.56 gears (from a 92 4runner) and am getting V6 3rd with 4.56 gears as well... I know that a V6 3rd will fit in a 4cyl rear and the 4cyl diffs are interchangeable front & rear so I assume a V6 3rd will fit in a 4cyl front housing correct I was told I only need to clearance the gear path on the 4cyl axle housing... also does any one have a thread on cutting off the link mounts on a 4runner axle and welding on leaf spring perches?
Old Apr 30, 2009 | 10:07 PM
  #88
4x4YOTA's Avatar
another question
from what Ive read my front axle measures 55.5"
and my stock rear is 55"
but my new V6 IFS rear axle is 58"
will I need 1.25" wheel spacers or does the front need to be .5" wider with 1.5" spacers
Old May 2, 2009 | 07:18 PM
  #89
4x4YOTA's Avatar
got my V6 3rds was able to get the front installed but then the weather got bad so the rear will be done tomorrow
front end apart
(V6 4.56 left) (4cyl 3.90 right)
Old May 2, 2009 | 07:20 PM
  #90
4x4YOTA's Avatar
now I just need to swap the drive flange so I can hook up my driveshafts
Old May 3, 2009 | 08:06 PM
  #91
4x4YOTA's Avatar
got the rear done today
Old May 4, 2009 | 06:44 PM
  #92
scooper's Avatar
I'm glad everything is coming together. I hope you cleaned the snot out of the thirds before you sealed them up, Im cringing looking at those gears and the dirt in the same picture.
Old May 5, 2009 | 01:17 AM
  #93
4x4YOTA's Avatar
I docked them in parts cleaner and cleaned the seal area and I will change the fluid again in about 500 miles
Old May 5, 2009 | 08:32 AM
  #94
dropzone's Avatar
Fossilized
i was thinking the same thing
cheap piece of plywood, tarp or cardboard makes a decent work surface...
also you can put the driveshaft up to the flange, rotate the DS 1/8 turn and drill...
Old May 5, 2009 | 08:41 AM
  #95
Cascade4Byer's Avatar
ive been tryin to get my cousin to sell his jeep and get a yoter. congrats!
Old May 10, 2009 | 10:08 AM
  #96
4x4YOTA's Avatar
yeah just got my cousin to get a 4runner
Old Jun 13, 2009 | 10:20 PM
  #97
4x4YOTA's Avatar
so the wife and I bought a new SUV so I get the Jeep as my DD and I would like to build my 81 into a play toy... plan is to get 3" trail gear front leafs custom rear leafs high steer and longer shocks...
Old Jun 13, 2009 | 10:24 PM
  #98
4x4YOTA's Avatar
built my rear leafs the other day and am happy with the result the main leaf is 2" longer than stock and more arch installed the leaf pack along with my 3" longer than stock shackle and I gained about4-4.5" of lift total above stock...
waiting to get new front leafs to see how I need to level the rear... right now I have a 3" longer than stock shackle and modified front springs for a total of about 3.5" of lift
Old Jun 16, 2009 | 04:00 PM
  #99
4x4YOTA's Avatar
ordered some new tires today got a great deal on some BFG MTs
Old Jun 18, 2009 | 08:59 PM
  #100
4x4YOTA's Avatar
tires are coming in early and I still havent picked rims yet I a looking for a set of 15x8 but not sure to get 3.75 or 4" backspacing... I will run 1.5" spacers up front and have a 4runner IFS V6 rear end but still need to weld on spring perches so not installed yet
