Need help with my yota!
A tap with a hammer should loosen the drive shaft from the output flange. They can be difficult and sometimes you will need to be aggresive. The shifter has a retainer ring at the bottom of it inside the housing(its hard to explain) Take 1 finger of each hand and slide down the stick shift to the base, then down inside the housing, inside there is a ring that has 2 flat edges and is spring loaded into the housing. use those edges as a pivot, push down with your fingers and turn at the same time counter clockwise. It is hard to do, but this ring releases the stick shift for (hahahah) easy removal. You already removed the boot, and in your pics I can see the ring that you need to depress. Hope you have small strong fingers. I once had this same problem and it caused me alot of headache. Good luck.
right there on the end of that shaft that comes out of the tranny...theres a big set screw there...take it out...then take the 2 bolts off of the tranny holding the shifter in place...that'll get that out
LittleUgly
15
01-02-2020 01:30 PM
primordialbeast117
12-19-2015 12:23 PM
