Pre 84 Trucks 1st gen pickups
MSD installed
Old Mar 13, 2007 | 06:00 PM
Phssthpok's Avatar
MSD installed
Well, it finally happened. I lost all spark today. So I caved and cracked the wallet for an MSD5 and Blaster2 coil. Fairly straightforward installation.
The only problem I have now is that my (aftermarket) tach needle is bouncing around 2K RPM at idle, but it smooths out and reads accurately (I think) once true RPM reaches about 2500.
Any suggestions?
Old Mar 13, 2007 | 06:50 PM
reggie 00's Avatar
Is the switch in the back set to the right engine type?
And when using the MSD box does that effect the switch in the back of the tach?
Old Mar 13, 2007 | 07:08 PM
toy283's Avatar
Is the tach hooked up to the tach lead on the MSD box or straight off the coil? If it is on the coil, it is reading the extra coil fires at low rpm and misinterpreting them thus giving the screwed up reading. As engine speed increases, the multi firing coil evens out and the tach gets a better signal to read. MSD provides a tach hook-up point just to eliminate this problem.
Old Mar 13, 2007 | 07:47 PM
Phssthpok's Avatar
Near as I can tell, there's no tach port on the 5 series MSD.
Old Mar 13, 2007 | 08:50 PM
toy283's Avatar
How about the tach adapter mentioned on the bottom of page 3 and shown better on page 4?
http://www.msdignition.com/pdf/5200_frm18162.pdf
Old Mar 14, 2007 | 02:10 AM
Phssthpok's Avatar
Yeah.....I saw that...but I was hoping to avoid it. Particularly since the truck is neither fuel injected nor a ford.
nvdesertrunner
May 11, 2020 08:18 PM
punks_is_4x4
Aug 21, 2015 01:35 PM
ripp96
Jul 31, 2015 11:14 AM
Esibnitsud
Jul 30, 2015 08:19 PM
