Pre 84 Trucks 1st gen pickups
motor mount help
Old May 4, 2006 | 01:50 PM
81yota's Avatar
motor mount help
So I rolled and ripped both my motor mounts off the rubber pad. I bought some stock replacement ones for now. I need some tips/suggestions on how to replace them. I have never done this before, so any help is great. Thanks.
Old May 4, 2006 | 02:33 PM
EWAYota's Avatar
get a hydrolic jack and use that to help lift the engine up. find a good place to place the jack, under the oil pan will be the best. make sure you have a block of wood between the jack and oil pan though. loosen the mounts, jack up the engine and replace the mounts. make sure you have your mounts on right before you lower the engine. when everythings back together, start the engine up and let it idle for a few minutes to let everything settle down, then turn it off again and retighten everything down.
pretty simple.
okamikai
Apr 30, 2018 10:19 PM
Scotto6591
Sep 1, 2015 03:24 PM
keithporter83
Jul 24, 2015 07:37 AM
tobylab
Diesel Swaps
Jul 17, 2015 06:51 PM
jon.r
Jul 11, 2015 03:34 PM
