Pre 84 Trucks 1st gen pickups
headlight and driveshaft questions
Old Jan 15, 2009 | 03:37 PM
Flek23's Avatar
Hey man before you replace them leafs you oughta get a hold of some of that prop-wash stuff...get em good and lubed up and then wrap them with empenage and see where that leaves you. As fer the brakes I'd grab some flightline extentions and stick them in there. Seein' as how well you handled that headlamp sitiation this'll be a breeze an save you a bundle.
Old Jan 15, 2009 | 07:14 PM
peckm888's Avatar
in my experience. i have an 82 and it used to have 32x11.5 tires. first off the engine had a little harder time turning them. but not too bad. the other thing is my tires rubbed when turned all the way either left or right. here is a pic of my truck from a long while back.
its now lifted about 10" with 33's.
If i were in your position, i would buy and completely install the lift first. do it right the first time and it saves money, in a way. i tried cheeting on my lift kit and it became spendy.
Old Jan 16, 2009 | 07:38 PM
YotaTheKid's Avatar
OK so just to keep everyone updated today i got paid so i bought the front leafs they are procomp 4inch lift springs and i got the rear shocks and they are procomp ES9000's. next paycheck i'm getting the rear leaf springs also procomp. i'm gunna start a build thread so you can all see my progress , hopefully i'll go up to the rubicon this summer HOPEFULLY hahaha later
Old Jan 17, 2009 | 06:17 AM
fyreandwater's Avatar
Good call on spring lift front and rear. Blocks are a really bad idea. I would reposition your front brake line brackets so the brake lines don't over extend if you wheel hard. You can keep your tires from rubbing on the springs by adjusting the bolts out on the back side of your hub. Not sure what they're called but they stop the wheel from turning too far and keep your tire from rubbing on the spring. You can do alot of damage if you're tire hits your springs. If you've got the money I would get 4:88 gears front and rear and at least a locker for the rear.
Old Jan 18, 2009 | 07:59 AM
  #25
Flek23's Avatar
I get the distinct impression due to the fact that the post was ignored that perhaps I went to far giving you crap. I'm a firefighter and we're tough on each other. I don't want to be known for beating up on new guys. I couldn't resist on the headlight thing but I wasn't looking to chase you off or anything. Good luck with your mods and welcome.
Old Jan 18, 2009 | 09:33 AM
  #26
Al's Chop Shop's Avatar
i have 33x12.50's on my 81, stock. the offset wheels make it rub on the firewall side of the fender. no big deal. should be fine with 10.50's, especially with stock wheels.
Al
Old Jan 18, 2009 | 05:37 PM
  #27
bruzryoda's Avatar
Damn, i forgot the blinker fluid, along w/headlamp fluid too........
i have 33 12.50s with stock for now suspention. there great, Dunlop mud rovers.
alittle rub when i turn right but, thats bout it. gonna get 3'' springs w/3" shackles. and a 1'' body lift and that will b all i need.......... then gears...... then bar the inside and out....... it never stops.
Old Jan 18, 2009 | 06:40 PM
  #28
YotaTheKid's Avatar
Yeah my plans are to do the 4inch lift, 33inch BFG muds, then 4.88 gears. front and rear locker (not sure what kind to get, any suggestions?) then sliders, armor (grill, tail lights, front and rear diff.) then roll cage then onboard air, not sure what after that.......MONEY!!!!! hahaha
4x4-runner
Apr 18, 2017 09:08 PM
mldave
Aug 10, 2015 09:23 AM
Tonetrk
Aug 6, 2015 10:06 AM
rushw
Jul 18, 2015 01:46 PM
icentropy
Jul 14, 2015 10:23 AM
