Pre 84 Trucks 1st gen pickups
GM upgrade Alternator 1981 22R
Old Aug 9, 2024 | 10:37 AM
drewgrimm's Avatar
Hi. Looking for tips and feedback on upgrading using LCE Alternator Bracket Kit (GM 1 Wire) setup.
LCE indicates their parts work with any of these GM alternators . Is there a standout choice I should buy , or consider them all comparable?
  • AIM/NAE (Napa) 67294
  • BBB Industries 72941w
  • Beck Arnley 1867294
  • Lester 7294se
  • Perfection 020854se100
  • Worldwide 53166
Also, I am a very much a novice when it comes to wiring projects, so wondering how difficult this is to upgrade. Is there diagrams out there with step by step instructions?
Thanks in advance
Old Aug 9, 2024 | 01:28 PM
osv's Avatar
osv
i put a 140amp gm 1-wire alternator on my 22re, using the trailgear bracket, it order to help power a winch that i didn't buy nor install until years later.
it was a bit of a hassle, not sure if wiring it for a 22r is much different... it takes it's own home run wire to the battery, i fused mine at the battery terminal with one of these fuse blocks:
Amazon Amazon
i haven't tested the setup under load yet, it's a powermaster alternator and the home run wire supplied with it is i think too small... powermaster no longer includes that wire, you have to add it yourself.
TCpickup86
Sep 20, 2017 06:38 AM
magentawave
Feb 3, 2014 09:55 PM
ToyotaLee
Jul 3, 2010 05:44 PM
dropzone
Mar 20, 2008 04:57 AM
frozenSurf
Nov 21, 2007 09:18 AM
