Pre 84 Trucks 1st gen pickups
Fuel pressure regulator won't go about 1.7 psi
Old Aug 20, 2016 | 08:55 AM
Danthewaterman's Avatar
I recently purchased a fuel pressure regulator from LCE, I hooked it up and the pressure will not rise about 1.7 psi. Any thoughts?
Dan
Old Aug 20, 2016 | 02:07 PM
wyoming9's Avatar
Can it be adjusted ??
What psi is it rated for??
How much pressure do you need??
Have you checked the pump output ??
If your pump is putting out the correct pressure and adjustments fail to work Poor Parts strike again
Old Aug 20, 2016 | 06:04 PM
The weber 32/26 should be ran between 2.5-3.0 psi. I checked the output from the fuel filter lead and it is at 1.7 psi.
88yotaaaa
Sep 12, 2016 06:36 AM
tylermac
Aug 15, 2016 01:02 PM
ryanespi
Aug 8, 2016 04:56 PM
oldyota02
Jul 26, 2016 08:22 PM
