Pre 84 Trucks 1st gen pickups
Engine dies when warm and on freeway 82 4x4
Old Apr 29, 2020 | 07:09 AM
  #41
Manuk Agazaryan's Avatar
Originally Posted by 13Swords
Nice work! Check your timing (if you haven't already) & make sure it's set (5 degrees before Top Dead Center, completely warmed up & at idle speed) and get some fresh spark plugs in it and it may start purring like a tiger Spark plug gap is .032". Don't overtighten your plugs when you install them.
Roger that! Check to all of those except the timing. I set it to 3° BTDC because I was afraid 5° might be pushing it, given its age and mileage. I'll give it a shot and see how she does. Thanks again.
Old Apr 29, 2020 | 07:18 AM
  #42
13Swords's Avatar
5 Year Member
Engine timing is engine timing, it designed to work best at a certain setting. Age & mileage shouldn't matter much, unless your timing chain is worn & slack. That would affect it more than anything else, other than your valves being out of adjustment. Easy way to check this is when using a timing light, if the mark on the pulley appears to be jumping back & forth, that's usually a sign that the chain is stretched out & slack. The mark should look to be in the same place (5 mark on timing cover) on every "flash" if the chain is good, or at least within a few (like 2) degrees to either side
anndel
Sep 10, 2015 08:50 AM
karuso86pu
Jul 22, 2015 10:39 PM
west_89_
Jul 30, 2012 04:57 PM
king132
Mar 18, 2010 06:59 AM
elguinness
Feb 6, 2008 12:16 PM
