ECM removal/1983 Canada emissions
Extremely long story short…
Moved from CA and I have an 1982 CA emissions truck. I now live in Oklahoma where there are hardly any Toyota parts and luckily there are no Emissions /smog checks. I Have a ghost problem with truck running and it has stumped several great mechanics even a Toyota certified mechanic. Narrowed it down to the emissions or ECM. I want to swap the emissions over to the 1983 Canada 4x4 can I do this and will it still run good? Do I bypass the ECM when I convert it to Canada 4X4.
Rebuilt long block re built carb. Less than 2000 miles. It seems I have heard of people doing this conversion.
2nd question is can I run the motor without emissions equipment and ECM. I already have EGR block off plates.
You can convert your truck to the Canadian version but the problem is the plug that goes to the ECM. The Candian plug is a lot smaller (not as many pins). If you can get a Canadian plug or old used harness you can spice the proper US wires into the Canadian plug and you will be fine. If you have a factory service manual all the wiring is shown. Also, remember to change your Emission vacuum lines, controls, etc to match the Canadian system. I live in Pennsylvania and if you drive under 5000 miles per year you are exempt from Emissions testing. Check to see if Oklahoma has a similiar law. I run no Emission controls on my engine.
kawazx636
Oct 6, 2021 03:03 PM
