Pre 84 Trucks 1st gen pickups
Eating Fuel Pumps.
Old Feb 27, 2012 | 06:10 PM
1981 4x4's Avatar
Eating Fuel Pumps.
My 81 is eating fuel pumps . I've put 2 working junkyard fuel pumps on it that worked for about a week each and put one off a running truck on it and after about 3 days it started sending all the fuel out the return line an none to the carb . i plugged it off an run it for a day or two then that one was done for an now i sit debating whether or not to buy a new factory style fuel pump or put an inline electric fuel pump. Opinions ? only thing i can think of thats wearing out the fuel pumps is the fuel line is bigger than factory an it maybe takes more pressure to pull it to the engine or something. any similar issues?
Old Feb 27, 2012 | 06:35 PM
dropzone's Avatar
Fossilized
Do you have the spacer the mounts between the pump and the head?
I was missing the spacer on my old 84 22r and was wasting pumps
Old Feb 27, 2012 | 06:38 PM
ledzeppelin3270's Avatar
What's the condition of your gas and gas tank? I have a buddy who had an old Ram that had a rusty tank, which isn't good of course, and then he siphoned some gas from an old tractor and put it in the truck. That gas was like varnish, and his pump stopped working a few days later. Of course, that could be coincidence....
1981 4x4's Avatar
are there like 2 rubber gaskets an 1 thick rubber spacer?
Old Feb 27, 2012 | 06:39 PM
1981 4x4's Avatar
i cleaned the gas tank an its pretty clean in the filter
Old Feb 27, 2012 | 06:47 PM
1981 4x4's Avatar
i think i may be missin the plastic spacer from head to fuel pump .
Old Feb 27, 2012 | 06:50 PM
That would make sense, then if that spacer is gone the cam might be moving the arm too much and causing failure?
Old Feb 28, 2012 | 05:59 AM
83's Avatar
83
Yeah, there should be a fairly thick (compared to the gaskets) plastic spacer.
Old Feb 28, 2012 | 06:04 AM
dropzone's Avatar
Fossilized
The spacer shown in the pic is on my 81. It is only about 1/3 as thick as the spacer on my '84. This has me thinking, I am gonna see if I can swing by and look at a friends 84 and his 81 for comparison pics.
Old Feb 28, 2012 | 06:57 AM
Bingle's Avatar
I went to an in line elec fuel pump (low press). Has worked great. Had to do it because manifold for dcoe's wouldn't fit with the mechanical pump.
My '81 had a 1/4" ish plastic spacer between head and pump.
Old Feb 28, 2012 | 02:51 PM
83's Avatar
83
Can't remember if mine started with a metal spacer or not...but the dealership sold me a thicker plastic one that's on there now. At least that's what I remember...it's been awhile since I've done much more than routine maintenance on my truck and some of this stuff is starting to fade a little...
Old Feb 28, 2012 | 04:13 PM
1981 4x4's Avatar
thanks for yalls help believe i got it fixed it had a black plastic spacer that was really thick an i still had a white plastic one that came off my original pump an i was a little thinner and put it back on an as of an hour ago it was all workin great.
Old Apr 19, 2012 | 10:36 AM
Doc Stockton's Avatar
Make sure you have the right spacer and two gaskets installed. I this doesn't help, check the eccentric on the front of your camshaft. It could be broken and damaging the fuel pump lever arm.
wafoogalla
Nov 2, 2016 11:02 AM
daddio
Aug 9, 2015 07:17 PM
Dakotaneu
Jul 27, 2015 12:03 AM
Hiluxtrucha
Jul 22, 2015 10:00 AM
Fundy Rider
Jul 16, 2015 01:35 AM
