Pre 84 Trucks 1st gen pickups
Carburetor Heat Spacer Help - 1981 Toyota 22R
Old Mar 7, 2026 | 07:39 AM
1981Toy4X4's Avatar
Hi All,
On my all stock 1981 Toyota 4X4 (federal emissions), I'm installing my rebuilt carburetor and replacing some air injection components. My question is with the phenolic carburetor spacer... I want to replace the spacer with a new one (with pre-mounted gaskets), however, Toyota no longer makes this spacer for my setup and good used spacers like the one I have are almost impossible to find. The spacer I have is basically solid with a small cutout for the PCV vacuum - The spacer that is available to purchase has the u-shaped slot for the PCV ports that are machined into the manifold (i do not have these ports on my intake manifold). In my research, some say the spacer with the u-shaped slot will seal off and work just fine while others say to use the old spacer and two individual gaskets. Hoping to get additional information on whether or not the newer available spacer will work for me - Hoping so as I would like to use the pre-mounted gasket setup.
Thank you in advance!!
BR549
Jul 13, 2025 11:22 AM
TRDrunner
Nov 1, 2007 12:05 PM
baileymoto
Dec 21, 2005 11:24 PM
BajaRunner
11
Jun 20, 2004 11:14 AM
tarheelrunner
Jun 8, 2004 09:53 PM
