Pre 84 Trucks 1st gen pickups
carb help
Old Jul 8, 2007 | 05:15 PM
kj1074's Avatar
carb help
i have a freshly rebuilt 22R, all new timing, ignition and valve components. it still idles rough after i rebuilt the aisan carb. is there any more i can do to the carb to help it idle better? are there people out there that rejet these things?
Old Jul 8, 2007 | 05:32 PM
myyota's Avatar
I have an 84 4Runner and a 85 truck, both are carbed and run just fine, when you rebuilt the carb are you sure that you got everything back together corectly ?, what about the vacuum line, are they all in the corect places ?.
Old Jul 8, 2007 | 05:37 PM
kj1074's Avatar
yea i actualy did it wrong the first time and went back in and fixed it. im pretty sure i got all the vacuum right according to the FSM. i just opened up the exhaust. i think maybe it just needs to breath more, maybe some bigger jets? i cant find anywhere that sells jets kits or anyone else that has rejetted them.
Old Jul 8, 2007 | 07:42 PM
myyota's Avatar
from what ive read here and on other forums, the jets from a weber carb will fit our stock carbs.
Old Jul 8, 2007 | 09:31 PM
the_supernerd's Avatar
Have you checked for vacuum leaks? That can cause a rough idle. Check the EGR bolts on the intake side, mainly the large bolt that connects the EGR valve to the tube. It needs to be tight to get a good seal. Spray some carb cleaner on it and see if your idle changes. If it does, then you have a vacuum leak.
Old Jul 9, 2007 | 04:33 PM
kj1074's Avatar
thats a good idea to try with the carb spray, but i know the egr is tight; ive been over that system twice. im starting to think that its just a worn out carb, throttle shafts may be worn causing internal vacuum leak, throttle plates out of round, etc...i still want a weber, anyone want to donate to the poor college student new carb fund?
Thamuel_
Domestic Swaps
Oct 3, 2015 11:15 AM
the_supernerd
Oct 1, 2015 09:20 PM
Rerun
3.4 Swaps
Oct 1, 2015 12:24 PM
Toys4parts
Sep 26, 2015 01:56 PM
taraf
Sep 25, 2015 02:57 PM
