Pre 84 Trucks 1st gen pickups
Axle questions
Old Oct 6, 2008 | 05:57 AM
1styota4X4's Avatar
quick update I got the rear axle with the arb installed and front pumpkin with arb and 5:29 gears in both with all wireing, lines, switches, and compressor for one hell of a deal...
At what point do I need to worry about the birfs breaking with the locker in the front. Looks like the consensus is 35" tires peroid but I was hoping for a little more insight
The truck currently has 32" tires and 3 in lift.
Old Oct 13, 2008 | 09:08 AM
ulfr's Avatar
It's not a bad move to upgrade to D60 joints instead of the birfs. But you might also just be abit "cautious" 'bout acceleratin' and turnin' at the same time you're usin' the locker.
Old Oct 13, 2008 | 09:18 AM
dropzone's Avatar
Fossilized
With the ARB just turn off the front locker if you are going to find yourself in a tight turn when you might bind the birf. With the 32" you will be fine for now. I have got a FROR Twin stick install in my truck to take it out of 4WD to avoid binding with an Aussie up front.
Hopefully I will be upgrading to LongFields after the first of the year. If you get 35's consider the Longfields as on upgrade but with the ARB Selectable you have a great advantage.
It would not be a bad idea to practice changing out a birfield just in case you do experience a broken one...Bound to happen sometime.
Old Oct 13, 2008 | 01:35 PM
1styota4X4's Avatar
i just rebuilt the frt axle and have to go in it again to replace a lug stud and pack more grease around the birf...I am going to just order the longfields i have some spare room on my oh so wonderful credit card that keeps buying toyota parts
Old Oct 13, 2008 | 01:50 PM
  #25
bigt's Avatar
i hear that brother lol
oldirtydirt
Feb 23, 2020 09:30 AM
polo451
13
Nov 20, 2016 07:49 PM
jerusry
Oct 19, 2015 05:28 PM
delmert
Sep 30, 2015 04:34 PM
deepmarsh
Aug 6, 2015 03:44 AM
