Pre 84 Trucks 1st gen pickups
alternator charging problems on 80 yota
Old Mar 21, 2011 | 10:40 AM
boochie's Avatar
hey guys i need some ideas on what possibly might be my problem here. i have a 1980 toyota pickup with a 20r in it. i have a new alternator and i replaced the voltage regulator. any ideas on whats happening?
Old Mar 21, 2011 | 10:46 AM
weaselman's Avatar
what are the symptoms? whats the problems?
why did you replace the alt and voltage reg??
Old Mar 21, 2011 | 11:25 AM
boochie's Avatar
My alt isnt charging my battery so i thought it went out. went and got it checked and its charging 14 volts. my regulator had some bad wires so i replaced the whole thing. it still isnt wanting to charge my battery.
Old Mar 21, 2011 | 08:50 PM
drokliss's Avatar
Are you sure you got the right alternator?
'81's and I'm assuming 80's as well originally didn't have a voltage regulator in the alternator (hence the external regulator).
I had a similar issue but found that the alternator was for an '86, and had an internal voltage regulator. I ended up having to use the connector from the external voltage regulator as a splice to charge the battery, bypassing the external regulator.
young buck
18
Aug 27, 2018 02:40 PM
redneck17
Oct 29, 2015 09:09 PM
msane99
Jul 17, 2015 10:13 AM
colinmil
Jul 6, 2015 04:03 PM
