Pre 84 Trucks 1st gen pickups
87 22r into an 81 pickup
Old Mar 22, 2010 | 09:27 PM
krelnydelnky's Avatar
hi there, im putting an 87 22r into my first gen. with plans of making it an re in the long run. Has anybody done this swap? if so obviously the cooling hoses are a bit different as to where they come off of the engine and go into the firewall. any advice on how to make it work? anything helps. Thanks!
[IMG][IMG][/IMG][/IMG]
Old Mar 23, 2010 | 08:15 AM
87hillbillyoter's Avatar
yenson-i posted this on marlincrawler to see if they knew
Old Mar 23, 2010 | 09:41 AM
xBANEx's Avatar
Getting ready to do this swap soon myself, will be interested to see what you find. I was sure to save the crossmember out of the parts truck I got, I gotta figure the 22r with a 5 speed is gonna need a different cross member location than the 20r with a 4 speed. I also found that it is possible to remove the complete wiring harness out of a 2nd gen without cutting a singe wire (although its a hassle) and same thing with the second gen, so everything should be plug and play for me.
Old Mar 23, 2010 | 02:55 PM
peow130's Avatar
Take all the stuff off the 87, too.
Like vacuum lines and whatnot.
I know the older pickups have a TON of lines on the fenders, while the later 22R's dont.
Old Mar 28, 2010 | 04:14 PM
ya i nailed it. some of the electrical was different and the cooling hoses were just a tad different. butttt i got her in. although it seems as if the engine mount holes were off slightly so i havent figured out if im going to drill them out or what not. thanks for the advice let me know when you decide to do the swap
Old Mar 28, 2010 | 04:25 PM
slacker's Avatar
I have done this a few times .. but quite a while ago ..
motor mounts are a bit different , you need to use the original ones . 9 wires if you choose to use `check engine lamp .. of course you`ll need to mount the computer . I drilled another hole right beside the original wire harness hole , for the EFI harness
sandyota
Feb 4, 2021 11:16 AM
Sep 4, 2015 09:27 AM
cars-guy
Jul 11, 2015 07:51 PM
Tyler Cunningham
Jul 11, 2015 10:18 AM
87blyota
Jul 10, 2015 04:31 AM
