Pre 84 Trucks 1st gen pickups
83' very jerky when maintaining speed and during slow acceleration
Old Oct 22, 2010 | 10:07 AM
traveljoe's Avatar
I did take the coil off and clean it. I haven't seen it arc since then. You're absolutely right about the internet. If it doesn't work as a source for research it is definitely questionable for my engine.
Old Oct 28, 2010 | 12:11 PM
traveljoe's Avatar
I may have discovered the root of my problem. I've long suspected that the cause was something surrounding the clutch or drive line. I was inspecting the connection between my engine and transmission yesterday and found that only the top two bolts are still in place! I promptly ordered the other bolts from Toyota and will install them this weekend. Needless to say, I'm not driving it until then. I sure hope this solves my jerky problem.
Old Oct 28, 2010 | 01:46 PM
duneyota's Avatar
keep us posted
Old Oct 31, 2010 | 01:31 PM
traveljoe's Avatar
I discovered that I actually had four bolts holding the engine and transmission together. However, two were loose, one of which was about a half inch out of the hole! I am also missing both of the stiffener plates! Two two of them are about $100 from Toyota. If anyone has another suggestion I would definitely appreciate it.
Although the engine to transmission connection does feel more solid while driving, the jerkiness is still there. I'm planning on rebuilding the carburetor in a couple of weeks. I'm pretty sure that's it at this point. I'll let y'all know!
Old Nov 17, 2010 | 05:49 PM
  #25
traveljoe's Avatar
FOUND MY PROBLEM!!! I had a massive vacuum leak. It was a split hose behind my carb. I don't know how the spray test didn't find it. Now my only problem is that I ran over a dead bear on I-5 about a week ago, so I have two collapsed leaf springs and some nasty reverb and vibration in my cab from the engine. I'm thinking it's probably a broken engine mount and the jacked up suspension parts. Everything else is normal and I'm SO happy to have my truck not jerk back and forth all the time!!!
crammit442
7
Nov 29, 2017 12:30 PM
Flossy
Aug 5, 2015 05:14 PM
Dennisx2
Aug 4, 2015 01:26 PM
91yotapup
Jul 27, 2015 07:19 AM
