Pre 84 Trucks 1st gen pickups
83 22R AC assembly removal. Can I? should I?
Old Feb 16, 2010 | 07:21 AM
toyospearo's Avatar
I am almost done with an 83 22r 4x4 timing chain job. The owner asked me if I could leave the AC assembly out. He wants all of it off. It has never worked and a PO told him the assembly was shot. There is a smog pump hose involved in the removal and I am wondering if it will cause any issues with the performance of the motor.
Are there any other issues if I take it out regarding smog or performance???
Old Feb 16, 2010 | 08:16 AM
toyospearo's Avatar
bump.. for some quick help
Old Feb 16, 2010 | 08:59 AM
skooterbumm's Avatar
will actually make the truck run better with out it, but wont pass smog.
Old Feb 16, 2010 | 09:12 AM
toyospearo's Avatar
Are there any parts I need to block off or hoses that need to be plugged?
That big hose that runs from under or near the carb that goes to the lower AC unit does it need to be plugged?
And or anything else I should do while I am dealing with the AC?
thanks
Old Feb 17, 2010 | 07:53 AM
Outsane's Avatar
you can pull it all out,
you will pass smog fine, skooter may be thinking about the pair system.
If there is any freon in the system then you "Should" have it reclaimed, any AC shop can do this. They may charge you up to $100 bucks.
You can check by pressing the presta valves on the low or high side and see if anything comes out. Its very possible that nothing will come out if it has not worked in years.
After that just start unbolting, be careful they lines are Alum and can bust easy.
Once you have everything off the engine bay side, Dryer, condenser, lines, compressor, you will be left with the hoses at the firewall. At this point you can either plug the hoses at the firewall or take the Evap out. Its under the dash and may be a pain in the ass. I'm not sure..
Old Feb 17, 2010 | 09:03 AM
I may have misread, i thought he was taking off smog pump too. I would plug any open lines, just because, or remove the parts like outsane said.
Old Feb 17, 2010 | 09:35 AM
Outsane's Avatar
no there is something in there about smog pump hose...
double check that the smog pump hose is part of the AC system, before removal..
Old Feb 17, 2010 | 02:55 PM
the smog system is not part of a/c maybe weaved among the a/c hoses. does the smog pump run off the a/c compressor belt? Mine is gone and i dont remember how its set up
Corvoid
Dec 11, 2015 11:21 AM
I8URSVT
Oct 5, 2015 05:42 PM
kawazx636
Sep 29, 2015 08:22 AM
Gurr
Sep 12, 2015 09:51 PM
