Pre 84 Trucks 1st gen pickups
82 toyota 22r timing chain
Old Feb 6, 2011 | 05:44 PM
slacker's Avatar
yep ..
the 20R duel chain is frequantly used in the 79-84 20-22r's ..
I have used them many times + they already have the metal backed guides
Old Feb 6, 2011 | 06:08 PM
xxxtreme22r's Avatar
slacker is it just as simple as changing just the timing kit? Like that was previously mentioned?
Old Feb 7, 2011 | 04:10 PM
slacker's Avatar
yes .. its all bolt on (different bolts easy to find ) .. there is one little "cetch" though .. you do need to replace the oil pump drive gear with the propper double chain unit
Old Feb 19, 2011 | 06:22 PM
js894x4's Avatar
Well i changed my timing chain with the right one Truck turned on with no problem. My camera was not working so i didn't have any pictures Not bad for my first time. I found these two posts that helped out a lot.http://www.4crawler.com/4x4/CheapTri...ds/TimingChain http://www.4x4wire.com/toyota/maintenance/timingchain/
Old Feb 19, 2011 | 06:31 PM
  #25
js894x4's Avatar
I did order the set with the steel guides but only one side was steel. The Guide with the curve was plastic according to the person i got it from(ebay) said that thats how the set came.
Old Jul 13, 2013 | 11:26 AM
  #26
TOYOTA PROSPECTOR's Avatar
Nice truck man!
fasterspider
Oct 6, 2015 10:24 AM
Ichneumon
Sep 27, 2015 04:21 PM
hexrain
Jun 27, 2015 06:17 AM
Badger62811
Jun 26, 2015 09:26 PM
paxanders
Jun 21, 2015 06:29 AM
