82 toyota 22r timing chain
Hey there i just purchased an 82 toyota pick up long bed, the timing chain was making that rattling noise so i order a new one online. My has a single timing chain and the one i order has a double roller will it fit. any advice
81-82's had a double roller long chain, 83-84 had a single roller long chain. 85-95 had a single roller short chain.
You sure your motor is original? If yours has a single roller chain it's not an 82 motor. And the double roller will not work.
Not sure what's actually involved in changing over those motors to dual row. It might be just as simple as changing over to the 81-82 timing cover. But not sure.
^^^^^^ Oh didn't know it wasn't for older engines just remember seeing it a while back. But you may have something there with the swap thing from an older engine.
If I wanted to look at the different components in the diagrams and parts listings between the two I can probably figure it out. But only gonna do that if the P.O. wants to convert it. Might be a shorter water pump as well, but not 100% on that either.
well the place i purchased my timing chain will exchange the one i ordered for the 83 version. it seems the did not have the double roller in stock anyway.
11302 COVER SUB-ASSY, TIMING CHAIN OR BELT 11302-38010 1978.08-1983.07
81-84 timing covers are the same looks like. Guess I should have looked up my parts references.
