82 4x4 pickup
You might check with Yoda Jim’s in Denver for used body panels or a local junk yard
You also might rent a stud welder kit and try to pull it out. They work great in pulling dents. The top panel is pretty workable but the corner may need extra work to get straight
Mike
82 roof repairs.
That would have worked but the rear window frame is messed up too. I have one coming from Denver that includes 6-8 inches below the rear window and the front window beams and part of the firewall. I'll drill out the spot welds and then remove mine. Fit it up and MIG weld in place. Also have rust damage in 2 small areas driver's side floor but that's an easy fix.
Mike
Mike
artofliphkd
Feb 1, 2012 07:19 PM
dixiemuddtoy
Sep 22, 2009 01:04 PM
wastedracing
Nov 16, 2006 06:38 AM
