Pre 84 Trucks 1st gen pickups
81 Longbed Build up (Slow)
Old Jul 1, 2010 | 08:18 PM
  #41
sokoji's Avatar
85triz - Yeah all I used was a roller and rustoleum, I also thinned the paint with mineral spirits (probably unnecessary) . There are places were the lint from the roller got stuck in the paint, but that my have had to do with the fact that I wasn't really using good quality rollers. I only did one coat on the truck pretty much. Although I like how it turned out, if I was to do it again, I would probably spend the extra time to spray it.
Yota81- I understand that the black interior doesn't mean that it was any kind of special addition, but mine was like this before the previous owner repainted it. https://www.yotatech.com/forums/f114...pickup-213759/
Old Jul 2, 2010 | 01:40 PM
  #42
theslowone's Avatar
u got a shiny vent.
very nice looking truck.
i also painted with roll on rustoleum ( sail blue)
u just sold me on getting the 33x10.50, when my 31's wear out.
Old Jul 30, 2010 | 12:36 PM
  #43
80banana's Avatar
Wow, I'm pretty impressed with your paint job being that you rolled it on. Wondering if I should do this to one of my vehicles....what kind of rollers did you use?
Old Jul 30, 2010 | 02:03 PM
  #44
2+2=4Runner's Avatar
I am looking for either a used long bed for the 80s pickups or a place that would make a new one...steel or fiberglass, anyone know where i could start looking?
Old Jul 30, 2010 | 04:29 PM
  #45
80banana's Avatar
Here's a place that sells fiberglass bodies http://www.jtoutfitters.com/fibergla...imv3e8t7patqc4
Old Jul 30, 2010 | 09:23 PM
  #46
landrover4wd's Avatar
nice rig!
Old Aug 14, 2010 | 04:34 PM
  #47
sokoji's Avatar
So I got around to working on the truck, did mostly interior work. Got a radio from an 04 Toyota Matrix and put in some 6x9 speakers in the door. Replaced the shifter boots with one from a third gen pickup. Put some reflexive sound deading stuff under the carpet and in the doors, now it is much quieter in the cab.
So recently put a new Weber 32/36 on my truck and it seemed to run fine down the road, but was getting pretty crappy gas mileage, and I did account for the bigger tires. So I checked the timing and of course it was off it was at about 12 btdc with no vacuum. But then I found that my vacuum advance wasn't working because the line was plugged. So I set it at 0 base timing then 12 btdc as per the FSM. Now it it has to be cranked for a good bit before it will finally start and will just barley run till you give it some good gas. I have been searching and some posts say to time the 22r base at 5 btdc. I'm not sure what I'm doing wrong its driving me crazy. Any help would be appreciated. I don't know if it matters but when I messed up my last head I replaced it with one from an 84 Celica with 22re and used the cam too.
Old Aug 14, 2010 | 05:32 PM
  #48
slacker's Avatar
http://www.toyotafiberglass.com
Old Aug 14, 2010 | 11:18 PM
  #49
wentz912's Avatar
Is the engine a pre or post 84 22R. I'm assuming that since you used an 84 celica 22re head that it is the early style. the early and late style motors use different degrees of timeing, i just can't remember which gets which.
Old Aug 15, 2010 | 07:03 AM
  #50
birder-93's Avatar
Hey nice truck and good luck with the rebuild!
Old Aug 15, 2010 | 05:23 PM
  #51
sokoji's Avatar
Yeah mine is a pre 85 22r block.
Old Aug 15, 2010 | 09:15 PM
  #52
sokoji's Avatar
So I decided I would like a bit more power out of my truck so I drove this home for $400.
Old Aug 15, 2010 | 09:22 PM
  #53
camo31_10.50's Avatar
seriously???
a diesel swap??
i'm down
don't know much about the Mercedes 5cyl diesels though.
got any power numbers?
Old Aug 15, 2010 | 09:33 PM
  #54
peow130's Avatar
is it naturally aspirated?
or turboed?
Old Aug 16, 2010 | 04:37 AM
  #55
sokoji's Avatar
For that year its supposed to have 123hp and 181lbs of torque stock, its a 1983 300sd. It is a a turbo diesel. It was pretty quick imo even for such a big car when I put the skinny pedal down.
Old Aug 16, 2010 | 05:11 AM
  #56
ROCK HOUND's Avatar
Sweet! Im hooked, i've always been interested in a diesel swap.
Old Aug 16, 2010 | 07:24 AM
  #57
yoder519's Avatar
OOOOHHHHHH yyyeeeeeaaaaa. now you got a build goin. youve really done alot to helo the looks of this truck. those 33x10.50s look great on there!!! and so does the interior
Old Aug 21, 2010 | 07:21 PM
  #58
sokoji's Avatar
So a little bit of progress got done on the swap so far took almost 7 hours start to finish to get it out; because I'm foolish sometimes.
Old Aug 24, 2010 | 07:43 PM
  #59
sokoji's Avatar
So nothing all that interesting, but picked up a w56 (at least I hope it is) with a newish clutch and flywheel and started to prep the block by taking off unnecessary stuff.
Old Aug 26, 2010 | 07:33 PM
  #60
sokoji's Avatar
So I pulled out the drive train out of the truck and test fit the diesel, its going to be pretty tight.
