Pre 84 Trucks 1st gen pickups
‘80 Toyota 4x4 - add power steering
Old Sep 1, 2020 | 10:43 AM
bcarroll76's Avatar
Hi all, I have a 1980 Toyota 4x4 Pickup that we need to add PS to. It has a 20r motor. I have searched the forums, but hoping someone can confirm what years PS setups would indeed work for us?
I know what parts I need, just need to know what years we can source them from and if it can be from 20r/22r(e)
Also, if you have what we need I am interested in buying it.
thank you!
Bryan
Old Sep 2, 2020 | 07:38 AM
slacker's Avatar
79-95 20r, 22r,22re , except for the box , box is 79-83 only .
you must be sure your head has the bosses for it though . some are NOT drilled
Old Sep 2, 2020 | 08:15 AM
bcarroll76's Avatar
Thank you! Exactly what needed!
Old Oct 4, 2020 | 09:10 AM
Groundpounder17's Avatar
Corey, why wouldn’t the later model boxes work? I thought most people preferred to use the ‘86-88 or ‘89-95 gear boxes? I’m actually accruing parts to add PS to mine and I had planned to use a box from a ‘86-88
Old Oct 5, 2020 | 07:48 AM
slacker's Avatar
you can certainly use them , its just there not a "bolt on" , you'll need to add a frame plate .
its a different system called hi steer .
Old Oct 6, 2020 | 02:37 PM
ok, I understand what you are saying now. I’m getting everything together to switch mine to power steering and high steer. It’s surprisingly hard to find parts for these old trucks, but with patience it’s happening
Old Jan 31, 2021 | 09:51 AM
jarstephens's Avatar
Do parts from 2wd models work as well? I would buy the refurbished 1979 4wd power steering box
Old Jun 29, 2021 | 06:11 PM
jladame01's Avatar
Hi Bryan, did you were able to find what you need?
I just got 1980 4x4 20R and looking to get also P.S.
Old Jun 30, 2021 | 01:16 PM
Bingle's Avatar
Just a bit of extra info/clarification on what Slacker correctly stated:
4WD
Option 1 - stock 79-83 power steering
79-95 PS pump works on all (not sure if same mount bracket on 20R?)
79-83 box/pitman (+possible drop drag link for those in the +/- 2" lift area)
Option 2 is to go high steer, but you have to have at least 3" of suspension lift to do this mod.
3" may require a low drop or flat pitman to clear, or clocking the box so the drivers side spring doesn't hit the pitman at full compression.
If you're at 4"+ lift, you really should do this because it's vastly superior for lifted rigs.
2WD rigs are a bit unknown for me, but my educated guess is that the pump is the same but the steering is a lot more like the later IFS and uses a "side to side" box rather than the "push pull" early 4WD style.
Old Jul 3, 2021 | 07:32 AM
slacker's Avatar
^ and be sure to use ATF in the system and NOT "power steering " fluid
Old Jul 3, 2021 | 03:13 PM
2ToyGuy's Avatar
Not that any idiotic moron on this forum would ever have used PS fluid in their PS in, oh, let's just say an 87 pickup, just for example, mind you, and wound up with failed gaskets on the pressure hose, worst leaking down into the alternator, causing it to fail repeatedly. Nope, no one here is that kind of stupid. No way. None of us. <AHEM!>
Nothing to see here. Move along, now, move along...
<name withheld to protect the stupid>
1980yota
Jun 29, 2012 07:55 PM
1980yota
May 10, 2012 07:59 PM
southernZ
Jan 25, 2011 02:26 PM
ESKIMO
Sep 9, 2007 01:04 PM
