Pre 84 Trucks 1st gen pickups
5speed from 94 2wd mounted to 20r?
Old Oct 25, 2006 | 08:43 AM
SupertoysAdventures's Avatar
I have a 94 22re 2wd w/5speed. Blew up the engine and am in the process of installing a 7mgte w/ auto. My friend said he would be interested in buying my 5speed if it would mount up to his 20r which is in a 78 4wd. Will it work?
Thanks,
Russ Walkup
SupertoysAdventures
Old Oct 25, 2006 | 09:08 AM
DudeBud's Avatar
yes same bellhousing he with have to rework the cross member location though
Old Oct 25, 2006 | 03:43 PM
slacker's Avatar
also some driveshaft work ..
Old Oct 28, 2006 | 12:08 PM
4XTOYOTAX4's Avatar
I swapped an ifs 5speed into my 82 4x4 mine is a 22r but the bolt pattern is the same. If you can get the tranfer case and tailshaft as well as the late model driveshafts it SHOULD work. I had to fab a new crossmember and redrill the front axle flange. I will try to post some pics next time im messing with the truck.
Old Oct 28, 2006 | 12:24 PM
kyle_22r's Avatar
i'm not sure about the length differences between the 2wd trannies, so you may have to relocate the crossmember and/or rework/replace the driveshaft, but it most certainly will bolt to a 20R.
80Truck
Oct 12, 2025 07:25 PM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
cb'sYOYO
Jan 7, 2016 09:08 PM
Pedalpwr27
Aug 13, 2015 06:37 AM
calderp
Jul 27, 2015 09:58 AM
