Pre 84 Trucks 1st gen pickups
5mge install on my 82 truck
Old Jan 28, 2006 | 11:16 AM
934rnr's Avatar
Well good news I just filed my taxes $3300 federal and $1100 state tax returns coming my way.
I am sure the wife will get a good part of it but the other money is going into my engine and putting a winch on my truck.
Something appealing is the STS turbo system http://ststurbo.com/
However I wonder if I couldn't make one of my own for cheaper.
I also have been checking out http://www.rabidchimp.com/ they have some adaptable oil lines and coolant lines for turbo charging the 5mge.
Old Feb 17, 2009 | 02:31 PM
camsshaft's Avatar
Get a small turbo that is sized correctly to spool very fast and be efficient and you'll do fine. I boosted my 22re 1990 cab and a 1/2. Hill billy shackles, flat bed,welded rear,jacked up torsion bars, Mitsu 16G turbo with water to air intercooler, a few diff sets of wheels and tires combo. That thing was unstoppable until the head lifted.
Get a smaller T3, use a water to air intercooler, a fuel pressure riser, retard the ign timing, use some arp head studs and a thicker headgasket you'll be fine. If you want to get fancy and technical put a cheaper wideband sensor and controller on it to see what your stoich ratio looks like and see if you can modify it at all on the cheap with fuel pressure.
voiddweller
19
May 2, 2016 09:10 PM
bigblue82
10
Jul 6, 2015 08:27 AM
88Toy
7
Jun 17, 2015 09:40 AM
