Pre 84 Trucks 1st gen pickups
4 sp &5sp Interchangeable?
Old May 18, 2022 | 03:13 PM
sent112's Avatar
5 Year Member
I have an 82 with a 4 speed tranny. If I found a 5sp out there will it just bolt up without any mods?
Thanks!
Old Jun 10, 2022 | 08:51 AM
sent112's Avatar
5 Year Member
Bump. Anyone?
Old Jun 14, 2022 | 02:22 PM
Bingle's Avatar
Important bit of information missing, 4x4 or 2wd?
If 4x4 your likely "L" series 4 speed trans is direct swap for L50 and L52 5 speeds.
W, G, and R series 5 speeds are longer and will require moving the crossmember back.
Old Jun 15, 2022 | 07:43 AM
sent112's Avatar
5 Year Member
My bad. Yes, it's a 4X4. How do I tell which tranny I have in there now?
Thanks!
Old Jun 15, 2022 | 11:02 AM
Bingle's Avatar
Best resource in my opinion:
Rebuilt Manual Transmission | Marlin Crawler, Inc.
Note, just because it says X trans for years A-B doesn't mean that's what's in there now if a previous owner slapped something else in. Dimensions and distinguishing features for the trans are on Marlin's site as well.
Old Mar 10, 2025 | 09:55 AM
sent112's Avatar
5 Year Member
Are there any markings on the trans itself to tell me what it is?
Old Mar 10, 2025 | 02:44 PM
Bingle's Avatar
If it has a 4 speed, 4x4 transmission, it's pretty much for sure a L45. I am not aware of any 4 speed 4x4 transmissions in later vintage Toyotas.
As said above, L series will drop right in, all others will require moving the crossmember back and probable driveline modifications.
Old Mar 11, 2025 | 07:07 AM
sent112's Avatar
5 Year Member
Am I reading this page from Marlin Crawler correctly. The 1983 trucks with a 5sp only had the L52? Also, They don't offer them anymore. Any idea where I can get one?
Thanks!
Old Mar 11, 2025 | 02:43 PM
Bingle's Avatar
You likely had a L52 original that was swapped by a previous owner for the 4 speed (probably because cheap). The door plate can be decoded to find what your original factory equipment was. My 81 supposedly came with a L52 (which supposedly wasn't available yet?? but there's a thread where others had this same thing)
Ebay and local auto wreakers/salvage yards are your likely only options for this vintage trans. Post about your approximate location and someone on here might have a good semi local place that specializes in Toyota parts.
Bajawfo
Jun 21, 2014 05:46 PM
mxstud1804
Oct 18, 2013 03:52 PM
dansouthwick
Mar 14, 2010 04:35 PM
93ToyKid
Jun 16, 2006 09:52 AM
