Pre 84 Trucks 1st gen pickups
20R/22R Distributor
Old Dec 5, 2007 | 09:26 AM
booger 746's Avatar
20R/22R Distributor
I have a 1980 Yota with a 20R engine.
The Distributor is messing up.
I want to know if a 22R Distributor will work in my 20R engine????????
If so, what years ?????
Old Dec 5, 2007 | 01:54 PM
lal357's Avatar
i dont see why not i just put a 83 22r in my 80 yota and i am using the ignitor and the dist. from the 80 on it so to me it should go either way
Old Dec 7, 2007 | 12:17 AM
the_supernerd's Avatar
The distributors appear to be identical. The advance curves of the 22R might be different than the 20R, but it would probably work. I put a vacuum advance from a 22R on a 20R distributor before and it seemed to work fine. What is your distributor doing?
Old Dec 9, 2007 | 04:41 PM
booger 746's Avatar
I have the wrong one.
The truck was given to me for nothing. I am in the process of get'n it going.
I will post a picture of what I got tomorrow. It only has a single vacum receptical on it instead of the dual receptical. I have dual vacume lines run'n up to it at the front of the head, but that is it.
I was look'n on Ebay and all I can find is 22R distributors.
One more thing. As I am dig'n into this I am missing all the "AIR INJECTION" stuff. Someone has removed it ALL !!!
Is this good or bad.
I thought this was some California thing but I guess this was on all 80 models ?!?!?!?!?
Old Dec 10, 2007 | 11:12 PM
A local parts store should have a new distributor for a 20R, and i doubt they would be too expensive, maybe a little over $100. If are going to save money and use a 22R distributor, make sure that the connector is the same and use the the vacuum advance port that is farthest from the distributor.
How exactly is your current distributor messing up?
I believe that the air injection tubes are for both California and Federal smog. If you need a smog check, you will have to put everything back. This system is not required for the vehicle to run. If you leave everything off, make sure that all of the open ports are plugged so you do not get any vacuum leaks.
Old Dec 13, 2007 | 04:46 PM
spindleshanks's Avatar
I just got a '79 pickup retrofitted with a 22R. The previous owner left a distributor cap, brand new in the box, behind the seat of the truck. He inadvertantly purchased a 20R cap, and it does not fit the 22R distributor at all. Totally different diameter on the distributor housings.
JonG85
Jan 18, 2023 04:31 PM
LittleUgly
15
Jan 2, 2020 01:30 PM
Sam hain
19
Sep 30, 2015 08:25 AM
EatChipsNow
Sep 9, 2015 01:25 AM
seab1209
Sep 3, 2015 05:41 PM
